blocking the stock bov
Old 03-28-13, 08:27 PM
rickytsui
rickytsui's Avatar
Default blocking the stock bov
where can i get a kit for this i just install my new bov and want remove and block the stock bov
does it even make a diff if i block it off or not ???
ricky
Old 03-29-13, 10:44 AM
Toyboxx
Toyboxx's Avatar
ricky
Unfortunately I don't believe anyone makes a block off plates for the stock BOV. I had to get one custom made, didn't cost more then $50 to get it done at my local shop.
Old 03-29-13, 11:16 AM
Ali SC3
Ali SC3's Avatar
If you want to just use the new one you could temporarily disconnect the vac line going to the stock one and that would disable it until you get a blockoff made.
you could run both but the new one won't be as loud cause its only doing half the work.
rdgdawg
08-22-09 10:31 PM
gmfeny
GS - 1st Gen (1993-1997)
05-04-07 01:26 PM
93lexgs3
04-07-05 08:02 PM
Quick Reply: blocking the stock bov
