What oil you guys running?
Old 03-17-13, 08:48 PM
Maserati
Maserati's Avatar
Default What oil you guys running?
Before i get hounded, i did do search and didnt really find a dedicated discussion on oil.
So! My question is what oil you guys using non-vvti & vvti? I was looking at royal purple. Any of you guys using the purple or any other oils can you chime in? which would be the best to use?
Old 03-17-13, 08:57 PM
3L4jzz31
3L4jzz31's Avatar
I usually run eneos in my SC but sometimes I'll use redline when I'm feeling baller :P
Edit: 10W-30 and always synthetic
TheAzn
TheAzn's Avatar
Mobil1 High Mileage 10W-30.
I've always used Mobil1 synthetics,
Old 03-17-13, 09:54 PM
durps
durps's Avatar
Mobile1 5w-30 high mileage. Want to try Amsoil next though.
Old 03-17-13, 10:28 PM
ashtray
ashtray's Avatar
Castrol Full Synthetic High Milage. Might consider Royal Purple from things I've heard recently. Goodluck.
Old 03-18-13, 03:57 AM
Natey2
Natey2's Avatar
2000 ES300 - Castrol 5W-30 for many years.
2005 LS430 - probably the same, haven't done oil change yet.
Old 03-18-13, 04:00 AM
2jzgttegs
2jzgttegs's Avatar
Amsoil all day!!!
Old 03-18-13, 09:20 AM
Maserati
Maserati's Avatar
Any of you guys VVTi? i thought 5W-30 was for lower mileage cars?
Old 03-18-13, 09:52 AM
TheAzn
TheAzn's Avatar
Technically, you can use 5W-30 at any mileage. It all depends on your engines oil consumption. Go a little bit thicker to lessen the oil consumption. I bought my SC and the previous owner used 10W-30 because he said there's a minor oil leak. But it does consume a significant amount of oil at high speeds... 90+ mph, heavy acceleration, although not enough to produce white smoke at any time. I was thinking of going to 5W-30....
I'm nonVVTi btw.
Old 03-18-13, 10:54 AM
eknine9
eknine9's Avatar
Originally Posted by 2jzgttegs
Amsoil all day!!!
I use amsoil, or Royal Purple depending on how I'm feeling and if there are any coupons.
Old 03-18-13, 12:15 PM
turbodremz
turbodremz's Avatar
Royal Purple only in engine, trans, and diff.
Old 03-18-13, 12:22 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I have used Castrol for every car I have ever onwed. Always will. Currently using 5W-30 in my SC with a 1JZ swap. I also live in a hotter climate than most. I think the type and weight of oil depends on where you live. JMO.
Old 03-18-13, 08:33 PM
Joey-E
Joey-E's Avatar
+1
Castrol is my preferred oil, I used Royal Purple once on another car it was pretty good
I got to try Amsoil or Redline one of these days.
Old 03-19-13, 06:50 AM
Luv2xl
Luv2xl's Avatar
German Castrol 0W-30 - 1JZGTE
edit: I've used the royal purple twice and it broke down so fast, the detergents in it I feel is what adds to the breakdown.. The Mobile 1 isn't what it once was to me and used it for most of the life of the swap..
Since doing research, I liked the characteristics of the German Castrol.. Doesn't breakdown as fast as the other oils I used.. I don't change my oil anymore at 3K intervals.. upwards of 4K.. and the oil still looks clean..
if you do a search here, I believe there is some nice input (personal opinions) on oils.. Supramania has a very nice article on oils and its characteristics etc..
Old 03-19-13, 07:00 AM
soarer93
soarer93's Avatar
1jzgte non vvti
stock twins 156k kms 80k by me -
i switch it up between the
Quakerstate Defy 5w30 (semi synth)
and Pennzoil Ultra (full synth)
I'd never use royal purple.
Quick Reply: What oil you guys running?
