Take a look at my frayed timing belt.
Old 03-03-13, 04:26 PM
Luxor
Luxor's Avatar
Smile Take a look at my frayed timing belt.
I am going to change it next weekend. What could be the cause of this? I am thinking the timing belt guide by the balancer pulley is rubbing on the side of the belt. What do you think?
Timing belt was last changed at 90K miles. Mileage on my SC is now 175K miles.
Old 03-03-13, 06:20 PM
StiCk3
StiCk3's Avatar
something has to be lose to cause that kind of damage, thats very abnormal. i hope you aren't driving it around like that...
Old 03-03-13, 06:47 PM
MzKaylee
MzKaylee's Avatar
that look scary.. yike!
Old 03-03-13, 06:52 PM
Candela
Candela's Avatar
holy ****. undo the whole face of the motor and see whats goin on
Old 03-03-13, 06:59 PM
SC300NW
SC300NW's Avatar
It almost looks like it's being pinched between some parts. It's a pretty consistent pattern.
Old 03-03-13, 07:04 PM
lookEVO
lookEVO's Avatar
Your tensioner is bad. Thats usually a sign of it. Make sure you replace it.
Old 03-03-13, 07:18 PM
TheAzn
TheAzn's Avatar
Yea, I say tensioner.
Old 03-04-13, 03:24 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
In fact, I'd replace all of the pulleys while you're at it, if they haven't been replaced recently. Good idea, get that timing belt replaced ASAP...don't want bent valves...
Old 03-04-13, 05:27 PM
Bankswood
Bankswood's Avatar
That depends on the year. If it is not a VVTi engine then it's not an interference engine and a snapped timing belt will not crash the valves.
Old 03-04-13, 05:51 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Do all the required maintenance since your in there. Thats what I would do.... good luck and be glad you caught it before it actually broke!!!
Old 03-04-13, 08:23 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Good point...
Old 03-06-13, 06:33 PM
dhhd
dhhd's Avatar
I think you are wrong, as far as I know the 1uz's that were in the 95-97 ls400's were interference and they were not vvti. They bumped up the compression from 10:1 to 10.4:1 and were now interference. I think the sc400 saw these changes too. Better be safe than sorry.
Old 03-06-13, 07:08 PM
1sWt2GS
1sWt2GS's Avatar
Looks like its about time to do a second change on your timing belt. Check your tensioner
Old 03-09-13, 06:52 AM
Jos
Jos's Avatar
Correct, according to something I read about the 1UZ in the LS, 1995 to 1997 had a redesigned head which now made the motor interference.
Old 03-09-13, 07:41 AM
jwin
jwin's Avatar
If you recently changed your crank pulley and use a pry back to pry it off you could have bent the washer and that could have hit your timing belt and chewed it up. Talking from previous experience.
Quick Reply: Take a look at my frayed timing belt.
