OEM gasket on Na-t manifold
Old 02-08-13, 09:27 AM
sj408
sj408's Avatar
Default OEM gasket on Na-t manifold
hey guys, dumb question but for some reason i remember the xs power gasket looking slightly different.
Are we able to use oem spec gaskets on these na-t turbo exhaust manifolds? id assume so but figured id double check
Old 02-08-13, 09:54 AM
Ali SC3
Ali SC3's Avatar
I used the stock one on mine, but I made my own intake manifold.
the xs power is similar, but seeing as we are all using the same lower runners, it should be fine.
Just hold it over the intake, and make sure none of the holes on the intake manifold are bigger than the gasket.
If is isn't and the bolt holes match up, you are good to go.
Old 02-08-13, 10:35 AM
sj408
sj408's Avatar
im sorry Ali i should have been more clear, i ment the exhaust manifold.
Old 02-08-13, 03:04 PM
Ali SC3
Ali SC3's Avatar
oh that makes more sense. I used the one that came with my kit. It seems much thicker than the stock one.
You can probably use the stock one but I imagine its less forgiving to imperfect header flanges as its not as thick as the aftermarket one. Bolt it up and check for leaks, but is a lot of work to redo if it leaks out exhaust.
dawhorl21
47
12-20-18 04:44 PM
darbs242
IS F (2008-2014)
12-14-13 07:01 AM
fried_rice
05-15-12 01:28 PM
bigblack06
03-05-12 04:53 AM
Sc dRifta
SC400 / 300 Classifieds
01-08-08 02:51 PM
Quick Reply: OEM gasket on Na-t manifold
