1JZ single turboo swap - hose questions
Hello guys,
i want to complete my single turbo swap an my 1JZ but i got some questions about some hoses first.
Here is a pic first:
What should i do with these lines?
red = ?
purple = ? (looks like a vacuum hose)
blue = ?
green = ?
I will put in a screw in this one:
This on is a little bent but i will tap this off too.
I hope you can help me, so i can finish my conversion.
Thanks for your help guys.
red = ?
blue = ?
green = ?
Thanks mate.
So i need to plug the red one + the valve cover one into the intake pipe right?
I found this tutorial here, maybe it´s a help for some peoples too.
http://www.lexusclub.co.uk/singleturbo.htm
Thanks mate.
The red one in the top pic is your coolant hose so that needs plugged back in to the heater core in let at the fire wall.
The valve cover vent either goes to the catch can or back in to the intake before the turbo or both as there is many ways to run them.
GsLex00
Performance & Maintenance
11-20-13 02:13 PM
9secCivic
01-05-08 02:23 PM
