Na-T Project
Old 01-13-13, 06:41 AM
A32Boost
A32Boost's Avatar
Default Na-T Project
Well i gave up on trying to start my sc300 and pulled everything out into a new shell, but this shell is not a lexus anymore . This is my 89 Cressida which i purchased that was already 5speed swap'd, with a 7mgte that had a rod knock.
i pulled the 7mgte out and put in the Na 2J in from my sc300, ran it for 2 weeks to make sure she had no hiccups then installed my turbo kit...
Specs:
1995 2jzge
mk3 W58
ACT heavy duty PP
ACT Sprung 6puck
FMIC
Precision SC61
Ebay ssqv Bov
Ebay 50mm Wastegate w/11psi spring
XsPower Manifold
XsPower Mk3 Downpipe
Rx7 550cc Inj
Apexi Neo
Aem Wideband
Pics:
Old 01-13-13, 01:20 PM
jwin
jwin's Avatar
Nice looking Cressida.
Old 01-13-13, 04:05 PM
sj408
sj408's Avatar
with your setup you shold check out running a GTE ecu considering your running 440s and such, i imagine it would run better than using the neo
Old 01-13-13, 07:12 PM
carsmypnis
carsmypnis's Avatar
did you use the 7mgte harness n ecu.if you do can install the injectors and not need a tune, u can also raise the boost pretty high without needing to tune.
Old 01-13-13, 09:01 PM
A32Boost
A32Boost's Avatar
thank you
that mightbe in the future plans but for now ill just wire in the 7mgte InJ and resistor box
im a full 95 ge harness and ecu
Old 01-14-13, 10:40 AM
Ali SC3
Ali SC3's Avatar
nice project. check out my tt ecu mod, the car will drive 100x better and you already have the 440's to match.
which mounts did you use to get it dropped in? good luck!!
Old 01-14-13, 11:28 AM
kez
kez's Avatar
Nice swap man any fly bys or exhaust vids
Old 01-14-13, 09:09 PM
A32Boost
A32Boost's Avatar
i looked into it alot prior but ill see how things go for now with my current setup and i believe they're oem jzx mounts brackets
no as of yet thanks
Old 02-19-13, 07:15 PM
A32Boost
A32Boost's Avatar
little update i ran into a set of rx7 550cc injectors that are high imp. direct drop in's
i have a total of 8 injectors
after some cleaning:
Old 02-19-13, 07:19 PM
A32Boost
A32Boost's Avatar
My next purchases will be a XSPower bolt on FFIM, q45 tb, then dyno on 11lbs. after i get the numbers ill start tearing her down to install arp's and a TT gasket
Old 02-19-13, 11:49 PM
acl99
acl99's Avatar
where is everyone finding Cressida's to do this work on!? I can not find one anywhere near me lol
Old 02-25-13, 04:39 PM
A32Boost
A32Boost's Avatar
small update just put my summer wheels on:
Old 02-25-13, 10:06 PM
lookEVO
lookEVO's Avatar
That looks hard as nails brah. Im super jelly.
Old 02-25-13, 11:05 PM
Kayasith95
Kayasith95's Avatar
You have no idea how bad i want this car! ****in grandpa sedans nobody would suspect a thing! I Love it!
Old 03-27-13, 02:30 PM
A32Boost
A32Boost's Avatar
a small update:
i installed my ffim,q45 tb, landcrusier throttle cable and my rx7 550s
the manifold had to be modified a little bit:
Quick Reply: Na-T Project
