passenger window issue
i know the passenger window issues are common however Ive searched and havnt found anything similar. to start my driver side window currently works, i had issues with it a few months ago and with the help of cl find a break in a wire, in the door harness between the door and body which i repaired and have had no issues with.
my passenger window currently does not work and i have found no similar breaks in the harness on either the driver side or passenger side. whats interesting is the led on the window switch is not lit up on either the drivers or passenger side however the led is lit up for the drivers window indicating to me that there is no power going to the switch. so i'm stumped any and all suggestions appreciated.
In Recovery Mode
First thing I'd check is fuses. popped ones create incomplete circuits.
if you look on your window switch panel theres an led that lights up the switch so you can see it at night. the switch for the drivers window is illuminate but the switch for the passenger window is not illuminate on either the drivers door or passenger door. both doors are on the same fuse from what i know and the fuse is fine plus the drivers window works
In Recovery Mode
