Starter, engine wire removal?
First post and I need a little help/
The starter is bad on my 97 sc400 and it has been a super PITA getting it off. I can not figure out how to get the rear water bypass off. The engine wires are in the way and I can not get enough slack to pull the rear water bypass up and off its studs so I can even get to the starter bolts.
Any ideas or advice will be greatly appreciated, very frustrated at the time.
Thank You
Thank You
