crank pulley/balancer came apart!
Re: crank pulley/balancer came apart!
Originally posted by sc300vb
anyone know if a supra crank pulley/balancer will work? also anyone out there have one for sale?
If your hb went out, that sounds like there could be a serious problem elsewhere. The modified Supra community is very wary of balancer problems that are the result of improper aftermarket clutch installations and aftermarket flywheels.
-scott
found out from the lex dealer that this is a common problem. it doesnt happen to all, but it is a design flaw. i also found out it isnt a harmonic balancer it just silences accessory noise from the cabin. it is a two piece design with a small amount of glue holding it together. i replaced it with a underdrive pulley from UNORTHODOX racing. you wouldnt believe the difference!! plus the cost of a new pulley is $300.00, i picked up the new underdrive pulley for $119 (normally priced at $235), they are on special right now till x-mas.
i recommend this upgrade to anyone, plus i did it myself in a couple of hours (pain free).
