Excessive Blowby?
Old 11-25-12, 01:42 PM
houndcomp
houndcomp's Avatar
Default Excessive Blowby?
I recently purchased a 92 SC400 and have been trying to fix it up. I have noticed it running a little rough and not having the power it should. I have done a complete tuneup, plugs, wires, dist cap and rotor with no change. I have also fixed a front seal leak and replaced radiator recently. I notice a white cloud of smoke on startup sometimes. What looks like excessive blowby to me when removing oil cap, puffing exhaust from oil cap. Also if i remove the air filter pipe from throttle body there is white exhaust coming out of throttle body while idling, giving it a bit of gas of course sucks it back into throttle body. There also seems to be oil puddling in throttle body pipe a bit, wipe it clean and its back in a minute. Any idea what would cause this?
Old 11-25-12, 01:45 PM
houndcomp
houndcomp's Avatar
BTW, this seems to be a recent development. Two months ago it ran like a scalded dog. I do not think it is the engine itself or even the head gasket. Possibly gasket, but doesn't seem like it to me. Any ideas?
Old 11-25-12, 10:21 PM
scott101
scott101's Avatar
I think you can tell if its the rings by pulling out the pcv hose when the motors running. if theres a good amount of smoke/steam then a lot is getting past the rings=blowby
thats what Ive read, hope that helps
-scott
Old 11-27-12, 10:01 PM
vangb2
vangb2's Avatar
-scott
+1 to this.
Also scorn cylinder side walls and warp pistons can really cause these types of effects.
Old 06-04-13, 05:53 PM
houndcomp
houndcomp's Avatar
So, I am finally getting around to working on this. Can anyone provide me with some ways to diagnose the issue rather than just saying it is rings. I understand it can be rings, but it could also be head gasket or valves right? How would I go about diagnosing it to find out what I am dealing with?
KKM
CT 200h Model (2011-2017)
02-21-19 07:46 AM
ISFCOBRA
IS F (2008-2014)
06-08-16 08:05 PM
CLightning
09-01-13 06:01 PM
bwilmoth
RX - 1st Gen (1999-2003)
01-30-12 09:44 AM
spxChrome
03-26-03 06:10 PM
Quick Reply: Excessive Blowby?
