Any one here running a supra tt cruise cable on a gte swap?
Old 11-19-12, 07:04 AM
xspsi6
xspsi6's Avatar
Default Any one here running a supra tt cruise cable on a gte swap?
Just curious as in looking at them it seems like it might work well but I figured I would ask here before I just go buying the 100.00 cable Google images showed it has been done before however since I have no 1st hand exp I figured I would be better off asking first
Old 11-19-12, 02:17 PM
soarer13oy
soarer13oy's Avatar
I have the cable and would recommend you getting one customized. It can work, but it is a bit too short. The cable will have to run over the turbos and valve covers.
Old 11-19-12, 05:15 PM
StiCk3
StiCk3's Avatar
your best option is to either find yourself a Soarer cruise cable or use a Supra TT cruise unit, which would involve removing/relocating your charcoal canister and extending the harness to reach it's new location. I got lucky and got a junk CC unit with my 1JZ swap and fits almost perfectly. Reaches the throttle no problem and works fine, but looks ugly going across my engine bay.
Old 11-20-12, 01:14 PM
93MSB
93MSB's Avatar
heres is my setup
its a tt supra cruise control unit. The cable is NOT modified. You do have to get creative to mount it in that location.
You will also have to extend a white/black wire on the body plug in order for it to reach the cruise control unit
Old 11-20-12, 04:05 PM
xspsi6
xspsi6's Avatar
Was that plug and play as far as the plugs go?
Old 11-20-12, 10:22 PM
93MSB
93MSB's Avatar
with an sc300 yes, the sc400's cruise control is wired a tiny bit differently
Old 11-21-12, 12:52 PM
xspsi6
xspsi6's Avatar
Ok so I am going to have to keep the 400 box and use the tt cable or find a soarer box with cable.
Old 11-21-12, 05:38 PM
93MSB
93MSB's Avatar
not necessarily, it may work with the sc400 I just can't confirm or deny it. IIRC there is one wire that runs through the engine harness of the sc400 for the cruise control. it's the only wire that's different.
you might pm tweaktech and ask for his insight
Old 11-21-12, 07:11 PM
xspsi6
xspsi6's Avatar
Ok I will do that when I order my harness here in a bit. Thanks!
JeffTsai
01-13-08 08:54 PM
turbosw20
SC400 / 300 Classifieds
01-08-08 08:09 PM
KAME
03-22-05 12:04 PM
2jzSC300TT
02-10-05 12:08 AM
atlsupdawg
02-02-05 01:56 PM
Quick Reply: Any one here running a supra tt cruise cable on a gte swap?
