Which al radiator best bang for the buck if you have 2jzgte swap?
I put an aftermarket tranny cooler on so now maybe it is time to upgrade my radiator. Does anyone make after market mounts that will work? Which aftermarket radiator overall fit and performs best bang for the buck?
Thanks - Sid
Thanks - Sid
Whatever you do, do not get a Fluidyne.
They used to make good radiators about a decade ago from the sounds of it, but now they produce complete garbage that is overpriced. I went through three of them. They all leaked either right after the install or after several miles of use. They will give you a hard time about returning it or getting your money back too if you call them directly.
Also, Mishimotos seem to have alot of issues as well in the leaking department.
Right now.... if you were to get any Aluminum radiator, it should be the Koyo. Pretty much everybody I talked to is happy with their Koyo. Don't try to save a few dollars and get a pos because you're gonna hate the cheaper product.
what about the lower mounts? did you just reuse your stocks and added the supra mounts to the top?
Guys I'm about to pull the trigger. So if koyo or mosh too do I need spacers and new upper tie down? I want which one is easier to install and fits the best. Price is the fial judging factor
Thanks - Sid
Thanks - Sid
RLJ
Performance & Maintenance
05-14-17 05:32 PM
japspec
07-20-10 10:25 AM
