turbo question!
Old 10-24-12, 03:26 PM
Shane7213
Shane7213's Avatar
Default turbo question!
going na-t on the stock 2jz-ge. stock computer. only going to run around 7 psi for a while. going slowly.
my question is, do I need to do anything computer wise on that low of boost?
Posted from ClubLexus.com App for Android
Old 10-24-12, 04:34 PM
8052JZ
8052JZ's Avatar
Honestly you should ditch the ge ecu if going NA-t as its not worth it and basicaly useless when NA-T. Do the TT ecu mod. A total of around 300-400 depending if you get new or used parts but well worth it for NA-t. I have half the parts already if interested PM me. Didnt use them becuase I had an AEM ECU laying around that I used instead.
https://www.clublexus.com/forums/sc-...t-ecu-mod.html
hope this helps and gl with your build
Sc300mk4
03-14-18 03:28 PM
Aswilley
06-06-14 03:39 PM
sc300jzTT
02-10-14 10:14 AM
Mr209sc300
SC- 1st Gen (1992-2000)
01-03-11 09:40 AM
SC3005SPD1
05-23-06 07:48 PM
Quick Reply: turbo question!
