sc400 95year diagnostic
Old 09-30-12, 09:44 AM
karolek98
karolek98's Avatar
Default sc400 95year diagnostic
Hello. I've got a problem with my car. I bought the diagnostic cable ELM327 OBD2 + toyota 22 pin. I installed all the software on my computer correctly and it doesnt work. Using program ScanTool. I know i can't do so much with this cable anyway i want to delate errors. I do all the things correctly, starting engine etc. Please help me with this.
Old 09-30-12, 02:01 PM
2jznosht
2jznosht's Avatar
were the 95's obd2?
Old 09-30-12, 02:09 PM
karolek98
karolek98's Avatar
Originally Posted by 2jznosht
were the 95's obd2?
well.. This luxus is probably obd1 but i got obd2 cable and looking for possibility to use it
Old 09-30-12, 02:57 PM
INTIMAZY
INTIMAZY's Avatar
95 is OBD1.
96+ is OBD2.
I'm not aware of any way to make OBD2 cables work on OBD1's since they are so fundamentally different. OBD1 never needs any special code readers. OBD1 code readers make life a little simpler but if you can count to 10 and own a paper clip, you can read OBD1 codes.
Old 09-30-12, 03:41 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
That's what i would do is read the codes. pull down the plastic cover for the diagnostic ports inside the driver side. Put a small wire or paper clip on the two locations. the bottom row far right and the other two over from it, same row. E1 and Te1. Good luck
Old 10-01-12, 02:05 PM
karolek98
karolek98's Avatar
i've done it. but got a small problem. removed the efi fuse 30amp for 20 sec. put it back and after 5 minutes i started enigine, and it didnt clear the trouble codes. what about removing battery groud cable? where is it located?
deputy865
04-06-13 07:48 PM
lexus400sc
Florida Lexus Club
09-16-10 02:07 PM
kabilano
07-16-08 07:18 PM
forcefed86
01-05-08 03:41 PM
sunny76g
07-02-02 12:15 PM
Quick Reply: sc400 95year diagnostic
