Sound Proofing?
Sound Proofing?
Hey so I've got some pretty mean road noise in my car and was thinking of getting those sound proofing mats (hushmat, dynamat, etc.) but wasn't sure if it really works. One reason my road noise is so high is because there are holes on either side of the trunk which I plan to cover with...something...(if you could help me there too that'd be greatly appreciated!!!) along with the sound proofing mat. If anybody has some ideas or knowledge or anything really it'd really help!
Btw, you can see the tires from the trunk holes....I though trying to put subs in the corners to cover them up might work...yeah idk I'm new to the car scene so don't pick on me hahaha but yes I did try search..I'm not new to forums.
Thanks!
Thanks!
to your question on whether things like dynamat work, the answer is yes. remember this, with things like dynamat you really are paying for what you get so don't cheap out. the best thing to do would be to cover everything under the back seats/ rear deck. good luck and welcome to Clublexus.
okay thanks!!
Do you have any experience installing it? I'm just not sure if I need to seal it with tape or that sealant they sell as well...don't wanna screw up a couple hundred dollar investment that will take quite a bit of time installing throughout the car lol
If you have rust/cut holes though the metal, they need to be repaired, if you are missing the grommets for the abs wiring, they need to be replaced.
Do you have a picture of the holes?
I just finished installing Dynamat Xtreme in my entire cabin... Floorboards, behind rear seats, and a double layer around the tunnel front to back. It took about 48sq. feet of material and I kinda ran out a little bit so I had to use a different sound deadener on the rear section of the floor. That's just to give you an idea how much of it you will need.
I've yet to drive the car, so I can't comment if it works or not.
Installing it is not too bad, it just takes time, and you're gonna be working in alot of awkward and uncomfortable positions, so be ready for that. And also, prepping the surface takes time too... vacuuming all that loose dirt and cleaning it for proper adhesion... it all takes time. Should be worth it in the end though.
Yeah I'm at work right now so guna take some pictures tomorrow when I get some sunlight lol but okay that makes sense.
You've got pictures or anything of when you were installing the mat? Sounds like a lot of work but tell me if it was worth it!! Cuz road noise is killing me...I can tell it's coming from front and back..how much did you spend btw?
Hey so I got my pictures finally but can't figure out how to upload them. Can check my facebook page cuz they're up there. Just PM me and I'll send you the link or my name or whatever...lol
Any help would be greatly appreciated!!
Dynamat or second skin, a lot of good mnufactures out there. If you really want to quiet everythingdown though I'd recommend MLV (mass loaded vinyl) on top of either the dynamat or second skin for road noise. I did my car from fire wall to the rear deck lid in second skin and then went over with MLV. Car is as quiet as can be. The MLV made a huge difference.
Shane
Shane
If you do Dynamat...ABSOLUTELY invest in the roller or you will want to slit your wrists with the metal.
The biggest thing about doing sound proofing is be patient, make sure you clean the area, and make sure that you use the roller to get into those contours.
I have about 1.5 boxes of dynamat coverage in just my trunk alone
ECUgs430
05-01-08 08:48 AM
