rear drive shaft
Old 04-15-15, 10:51 AM
Dtaylor3
Dtaylor3's Avatar
Default rear drive shaft
Im trying to remove the rear drive shaft so i can change my wheel bearings, but having trouble getting the drive shaft detached. Any tips?
Old 04-15-15, 06:05 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Moved to maintenance.
https://www.clublexus.com/forums/per...t-removal.html
Old 04-16-15, 10:06 AM
Dtaylor3
Dtaylor3's Avatar
Im talking about the half shaft connected to both rear wheels, attached to both sides of the differential
Old 04-19-15, 01:22 PM
Dtaylor3
Dtaylor3's Avatar
Anyone have a clue how to get it off?
Old 04-19-15, 06:40 PM
lexsc3
lexsc3's Avatar
Ive only done it by dropping the diff and removing the nut in the center holding it in from the spindle. They dropped out of the spindle but my axles were rusted into the diff so I couldn't get them to disconnect from that end. From what Ive read the way to get them off is to get a slide hammer and a special axle removal tool if they are rusted like mine. There is most likely a way to get them off without dropping the diff by disconnecting one control arms to give enough slack. There might be enough slack in the axles themselves to slip them out. How are you going to press out the bearing without removing the spindle?
Old 04-19-15, 11:51 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
Mark the flange connection [1/2 shafts and the differential] and separate them by undoing the 6 Allen head bolts. Raise both rear wheels of the ground and spin the wheels to get better access to the Allen bolts 1 or 2 at a time. Once separated support the 1/2 shafts and make sure the ends are not pulled to prevent separating the flex joint.
Since I was replacing the output seals, I had to drop the exhaust. Not a biggie, but I think you wont have to.
Match marks on reassembly.
Salim
Old 04-20-15, 09:07 PM
Dtaylor3
Dtaylor3's Avatar
preciate all the help.
Returd
08-22-17 11:26 AM
newgsman
05-22-14 04:24 PM
Overclocker
30
10-13-02 10:17 PM
TomSC400
SC- 1st Gen (1992-2000)
03-11-01 05:18 PM
TomSC400
03-10-01 09:36 AM
Quick Reply: rear drive shaft
