swap help - ECU???
Old 10-01-12, 07:40 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Glad we could help you out. Now post some pictures of the swap, we want to see.
Old 10-01-12, 09:23 AM
Ali SC3
Ali SC3's Avatar
yeah pictures are always a big plus. so what did you do to fix the inconsistent idle?
Old 10-08-12, 06:01 AM
Daddy0
Daddy0's Avatar
needed back pressure from exhaust to get o2 sensors reading right, it runs good now. Also did a lot of throttle adjusting to get low idle right and WOT.
we took the diff out and welded it last weekend.
pics? sure, I got lots! I'll post tonight when I get home, my work network doesn't let me get to Photobucket.
Only thing left is coil-overs, so don't laugh at how high it sits, we got powered-by-max coil-overs coming next week. And wheels are not on it yet either, we have some Rustang wheels cheap but don't want to put them on unil it's sitting right. We finally got a hood, but because I did not relocate the front sway bar, my motor sits too high and i had to cut the hood.
Old 10-08-12, 05:08 PM
Daddy0
Daddy0's Avatar
Old 10-08-12, 08:51 PM
Ali SC3
Ali SC3's Avatar
wow, looks like a lot of work is going into that FC. maybe you can get a turbo II vent to cover the hole in the hood.
should be a fun car when its finished, good luck!
Old 10-09-12, 03:33 AM
Daddy0
Daddy0's Avatar
Yes, gotta make a few more mods to hood for fitment and then yes, some type of hood "scoop" is def the next step. After coil-overs is a cage.
again, thanks for the help guys!
Rising_Sun
05-01-09 01:32 PM
parnzen
12-16-07 06:26 PM
LocknRoll
04-09-06 09:07 AM
Quick Reply: swap help - ECU???
