SC 12V fuel pump mod- 1JZ
Old 08-17-12, 06:03 PM
speed6
speed6's Avatar
Default SC 12V fuel pump mod- 1JZ
If i do this, will the car still have a boost cut?
Old 08-17-12, 07:05 PM
MDSC
MDSC's Avatar
yes boost cut is controlled by map sensor not fuel pump, you need Boost Cut Defender if you want to get rid of it
Old 08-18-12, 03:52 PM
StiCk3
StiCk3's Avatar
yep, 12V fuel mod is just to bypass the fuel pump ECU that controls low engine speed fuel pressure on the stock engine. It is not involved with fuel cut as that is controlled by the engine ECU. As mentioned before you will need an FCD to bypass this.
Old 11-25-12, 09:33 AM
speed6
speed6's Avatar
i may have my HKS fcd for sale.. will know more in a few weeks
Old 11-25-12, 05:07 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
If you decide to do this, I would bypass the OEM fuel poump relay all together. I would run a 8 or 10 gauge wire to a seperate relay and call it the day. trigger it on with a seperate source when key is turned. JMO..
Lexus082
07-10-14 09:31 PM
soarer1988
07-04-14 12:28 PM
2jdeemo
03-24-14 02:36 AM
OBEEWON
06-26-12 05:07 AM
808SC300
Maintenance
01-18-04 11:22 AM
Quick Reply: SC 12V fuel pump mod- 1JZ
