2jzgte swap...wont crank
i apologize for wasting everyones time there were 2 plugs unplugged from the body harness on the driverside that go to the engine they are the 2 black main connectors...smh. I plugged them in got check engine light. Jumped 3 and 5 on starter relay and she fired right up ran smooth. Then started to idle low. Check engine flashed out code 25...o2 sensor too lean. This harness came with a 4 wire connector for supra ecu and i read somwhere that i could just buy a supra oem o2 which i did but the wires were too short i extended them one by one. But i gess maybe the computer dosent want to see a 4 wire o2? I also have the regular swap problems i gotta adress, tach not working and car wont start with the key. Hopfully omar can lend me a hand after work and we can figure these 3 small problems out. Thanks everyone to try to help a dummy
Car is running , tach is working.
The car won't start with the key because it's an original manual car, but running on Aristo ecu , NSSB.
So the Ecu still need to think the car is either in N or P.
I have the same problem done with the aristo convertion on my sc300 auto tran, and stock tt.
The car cranks but no spark at the coils and no fuel to the engine, what you guys think?
LEXXIUM (11-09-20)
