Clutch info
Old 07-02-12, 06:27 PM
scweetfl02
scweetfl02's Avatar
Default Clutch info
Does anyone now the torque value for the flywheel bolts on a 1jz vvti?
Old 07-02-12, 06:55 PM
blk&blu*j
blk&blu*j's Avatar
74 Nm DO NOT reuse flywheel bolts and always use Loctite.
GL.
Old 07-03-12, 08:37 PM
scweetfl02
scweetfl02's Avatar
Locktite? For what? Then if I ever change the clutch again ima strip the bolt heads
Old 07-03-12, 09:18 PM
vangb2
vangb2's Avatar
Loctite acts like a lock washer, except the fact is that you can't use a lockwasher. If you ever strip your flywheel head bolts while removing it, it's not the Loctite.
Old 07-05-12, 06:38 PM
scweetfl02
scweetfl02's Avatar
Okay dudes thanks for the intel
tjmhillz
05-16-16 06:30 PM
drewdizzle
SC- 1st Gen (1992-2000)
02-15-11 05:23 PM
THMotor
Club Lexus Vendor Marketplace
05-28-09 06:46 PM
newyorksc
25
11-22-04 03:08 PM
Quick Reply: Clutch info
