97 sc300 1jzgte swap! Need help ASAP with wiring
hey everyone, I'm currently in the middle of a swap with a sc300 using a jza70 1jzgte motorset, has anyone done this swap before? i know the wiring is a pain in the A** but i just looking for someone to point me in the right direction on what has to be modify in the 1jz-gte harness? Searched the forums and no answer, any help would be greatly appreciated, THANK YOU
I did my research and found out you have to remove the four body plugs off your 2jz-ge harness and rewire them into the 1jzgte harness, is this true? and is there anything else that has to be done to the harness?
If you're good with wiring I would use this:
https://www.clublexus.com/forums/per...fo-thread.html
If your not good with wiring I would send that harness out . It might be expensive but your time is money and it will pay off in the long run.
