1JZ swap/SC400 A/C not kicking on
12-29-12, 03:23 PM
My brain is all scrambled. I can wait. I still don't drive it daily. It just sits there. I was just tinkering with the car today.
12-29-12, 06:30 PM
1JZ Single SC400
12-29-12, 09:37 PM
Just basic stuff. I want to install the BC 264 camshafts, I need to put in a bigger fuel pump, clean my injectors and fuel tank schedule a re-tune and hope I get above 500 horsepower. If I mirror your setup I'm sure to succeed.
04-10-13, 09:22 PM
sorry to bring an old thread back to life. I have the same issue but mine is 1JZ VVTI. can you help me with this? thanks.
04-11-13, 07:31 AM
1JZ Single SC400
Did you try my method exactly?
04-12-13, 07:07 PM
My mechanic told me that he tried switching the AC controller from his sc300 into my sc400 and it didn't work. He also tried to adding the relay switch but he doesn't exactly know where to start. Not to mention he is not exactly sure which car the 1JZ VVTI came from. Any idea what I should do next? Thank you so much.
05-03-15, 05:54 PM
MARK!!! is ur ac still working??
06-08-15, 07:42 PM
guys guys guys!!! so in terms of PRE aem, how do I wire this up(feel free to use windows paint to make me a diagram).
06-09-15, 08:29 PM
wow, anyone?? what happened to this site?
07-03-15, 09:00 AM
well thanks guys(not really). I didn't have to re-wire anything and all I had to do was charge the system. so thanks again guys!
09-03-15, 03:56 PM
so NOW I have to wire in my ac pins for my aem jumper harness. I will supply pics when I get this done(hopefully soon).
04-15-16, 11:25 AM
ac switch input= multiple options. I just selected "switch always on"?
04-17-16, 10:51 PM
paging mark!!! which option did you use?
04-18-16, 03:18 AM
Super Moderator
Jim - do you want Mark's phone if you don't have it ? I got it .
Switch option depends on what is available .. you can use any LS (low) switch that is not used .
06-24-17, 08:47 AM
bump, having the same issue again!!!
AZOliT
SC- 1st Gen (1992-2000)
10-17-13 11:54 AM
Lokz
Build Threads
33
05-12-13 03:17 PM
wilsonsan
GS - 1st Gen (1993-1997)
04-11-11 01:06 AM
jinsoku3g
Performance & Maintenance
05-15-10 09:57 PM
MadMaxxNA
08-09-05 03:50 PM
1992 ,
1jz ,
1jzgte ,
ac ,
convert ,
gauges ,
idle ,
lexus ,
low ,
sc400 ,
speed ,
swap ,
turn ,
wont ,
work ,
working
