2JZGTE idle low, rich, A/F read 12.5
Hi!
I hope 2JZGTE guys here could help me!!
I've been searching all around the internet and here and couldn't find the right answer I'm looking for!
So a friend and I just finished a 2JZGTE swap into my Toyota Soarer and now that it started, the idle is low, around 600rpm, and smell unburned gaz from the exhaust,
The A/F read 12.5 so that's pretty rich
After 5min of warming, idle change to 800, but still rich with the 12.5 reading of the A/F.
So my questions are:
What the ****** have we done wrong?
And how to we fix it?
Thanks guys!
Thanks guys!
Hi!
Thanks guys!
Thanks guys!
Sorry need a little more info. Extended harness, injectors, management, FPR, age of fuel.upgrade fuel pump or pumps????????
Stock injector from this engine, haven't been changed, never tested it's his first starts since I buy the engine in chrismas.
No management yet installed but soon, old fuel from septembre when I broke my 1JZ. stock soarer fuel pump!
Need more info?
That's a 2JZGTE from Toyota Aristo, with the harness and ECU. the 1JZ part we sold in was for the body loom as I wrote up. And surely jdm 440 as they aren't changed. So the problem could be the injector itself?
either the map sensor from the 2jz, or from my 1jz, do the same thing.. no change, and I do not thing the would be both broken. Was working correctly on the 1jz in fact!
when it's suppose to be 14.7? well I find that rich..... and smell it too!!
I realize as stated you swapped maps 1J-2J but have you actually checked the continuity from the map to the ECU ?
Also try checking the coolant temp sensor as this will also put the car in a sort of limp mode the car will dump fuel for safety and pull timing, just a suggestion
did you drive it around? if you just start it up and let it idle, it wont learn to lean out and will just run rich.
you have to actually drive it around for the ecu to start learning from the o2 sensor.
if after 20-30 minutes of city/highway driving you arent seeing any changes, check the wiring on the o2 sensors.
also make sure you are using a heated o2 sensor for best results.
Didn't think about the coolant temp sensor!! I'll check that!! Thanks!
Thanks!!
You've got it for one of the two problems!!!! The ecu seem to have learn everything for the o2 sensor as my car no longer run rich, at idle, hot, it stay between 14.3 and 14.8!!! Pretty perfect to me!
But at cold start, the rpm is still at 600rpm.. Don't know why yet! If you know something let me know!!
I knew it was that because my aristo ecu idles at the same thing before it learns/warms up, so it had to be the o2 sensor. I also noticed it took me like 3 drives after a battery reset before it started to move from that afr. like it was a slow learner but got there eventually.. lol.
check your idle air control valve, if it is functioning but maxed out, you may need to set the throttle stop position (crack the tb open some) to help give it some more room to self adjust (it can only open so much on its own). I bumped mine up to about 900rpms, cause I have a killer clutch.
