Is there an easier way to reset CEL and pull codes
Old 05-17-12, 02:02 PM
GamblerZ
GamblerZ's Avatar
Default Is there an easier way to reset CEL and pull codes
...to read the engine codes once the Check Engine light comes on?
Also, is there no easier way to reset these codes than to disconnect the battery and turn on the headlights for 10 minutes? Disconnecting the battery is not only tedious, but time consuming given everything that has to be reprogrammed (ie. stereo, clock, windows, etc.).
Old 05-17-12, 02:41 PM
OG Dada
OG Dada's Avatar
Only way I know how to reset ECU was disconnect battery terminal, switch ignition to ON/OFF twice.
Old 05-17-12, 03:13 PM
Ali SC3
Ali SC3's Avatar
Is there an easier way to get new members to post descriptive thread titles instead of me having to to edit them all?
probably not.
No, there is no easier way to pull the codes if you are odb1, you must read the all knowing blinking light, or get one of those expesive special readers.
and YES, there is an easier way to reset the ecu, its called pulling your efi fuse in the main fusebox.
I still find it easier to slip off the negative lead and that seems to do it right away for me.
Old 05-17-12, 04:54 PM
GamblerZ
GamblerZ's Avatar
For those who are removing their battery terminals on a semi-regular basis, wouldn't it just be easier to install a simple battery cut-off switch? Something like this at Harbor Freight for only $9.99?
Old 05-17-12, 06:19 PM
CrazySC300
CrazySC300's Avatar
I just find it alot easier to just pull the efi fuse.
Old 05-18-12, 07:45 AM
Ali SC3
Ali SC3's Avatar
I use one of these, works well with battery relocations as well.
http://www.cartoys.com/products/prod...ircuit-breaker
BocaVdub
06-29-15 05:27 AM
94esjag
10-27-09 12:06 PM
colenzae
RX - 1st Gen (1999-2003)
10-12-09 12:51 PM
JacobT
02-02-05 12:52 PM
clark
05-14-04 02:05 PM
Quick Reply: Is there an easier way to reset CEL and pull codes
