difference between 1uz-fe and 2jz-ge AFMs
Need some info here guys; spout the info that you know about these AFMs
They are both Karman Vortex setups...
are they the exact same AFM? or does one flow better than the other?
I always suspected they were the same; but after visiting MK3 country for a couple days; I've found that the Lexus V8 AFM flows exactly 25% more than the MK3 turbo AFM does...
and the stock MK3 injectors are 440cc; you can upgrade to 550cc which are 25% larger than stock... and this mod is proven to work with a little tuning... its the Reg Reimer mod from SONIC...
and I was curious if anyone knew if the 2jz-ge AFM is the same one in the 7m-gte
just got a confirm from a MK3 guy that the 2jz-ge AFM and the 7M-gte AFM ARE the SAME!!!
that means we can do a similar swap...
1uz-fe AFM swap and 25% bigger injectors
now I need an exact size of 2jz-ge injectors...
are they 330cc or 380cc? I've heard both
