GTE swap, AC only blows cold when set to COLD
Old 05-10-12, 07:46 PM
93MSB
93MSB's Avatar
Default GTE swap, AC only blows cold when set to COLD
so I'm having an odd issue with the climate control. everything seems to be working fine except that the only time I can get the ac to blow cold is when the climate control is set to COLD. if I put anywhere above that hot air comes out.
I have a 1jz on an aristo harness an ecu, I did the resistor mod to the ac terminal at the ecu so the compressor is functioning.
just curious if this was normal or if anyone has run into this problem before
UncleRico
GX - 1st Gen (2004-2009)
06-21-19 04:26 PM
pmnuon79
01-05-17 08:37 PM
svlexus
03-28-11 07:47 AM
ajcsanders
06-26-06 01:41 PM
Quick Reply: GTE swap, AC only blows cold when set to COLD
