1jz swap and air conditioning help!
Old 05-07-12, 09:15 AM
wirelesstj
wirelesstj's Avatar
Default 1jz swap and air conditioning help!
For those of you who have a 1jz swap....how did u work with the a/c?? my a/c will blow out cold for like 10 secs. and then shut off and then the a/c light will come on and flash and it will go into a limp mode. I really dont want to put the a./c on a direct power switch, i would rather have it work off the climate control. i noticed there wasnt a "dedicated" thread for this hence the post. any help is appreciated!
Old 05-08-12, 09:04 AM
wirelesstj
wirelesstj's Avatar
Bump..........
Old 05-08-12, 09:45 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I havent charged mine yet. I will kniw more once i get it tuned. how much pressure do you have? Within the standard pressure?
Old 05-08-12, 11:55 AM
wirelesstj
wirelesstj's Avatar
Its holds pressure fine....it just goes into limp mode after 10 secs of blowing cold
Old 05-08-12, 02:38 PM
INTIMAZY
INTIMAZY's Avatar
I never touched my A/C when I did the swap. Not sure why exactly you did?
Old 05-08-12, 03:04 PM
xspsi6
xspsi6's Avatar
Is the pressure switch cutting the current to the clutch? Pressure to high once it starts to compress?
Old 05-09-12, 08:12 AM
TweakTech
TweakTech's Avatar
You need a relay wired in under the dash between the ECU and the blower motor connector. PM me for details.
-Cam, Tweak'd Performance
Old 05-09-12, 09:13 AM
wirelesstj
wirelesstj's Avatar
U live in NY......i live in AZ. why wouldnt i want a/c in my car??????
Old 05-09-12, 09:34 AM
Vrank
Vrank's Avatar
When I did mine, I left the compressor from the ge engine hooked up and in the car, then bolted it to the 1j. I put the pin designated a/c to the same pin on the 1j ecu, then put the pin labeled acmg to the same one on the 1j ecu. Haven't had it cut off yet. When I was using the aristo ecu I wired in a high sensitivity relay to get the compressor to kick on. Is there some kind of code that the a/c light is trying to give you?
Old 05-09-12, 11:06 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Now this thread is getting interesting. Do all the swap 1jz's need to do this. I am running a AEM V2, not a factory ECU. Does this make a difference?
Old 05-09-12, 01:00 PM
INTIMAZY
INTIMAZY's Avatar
I had A/C before... and still do. Never lost it, never recharged it. It all worked as it did before.
Old 05-09-12, 03:04 PM
StiCk3
StiCk3's Avatar
Mine worked briefly when i swapped my engine in initially. Ran into an issue a few months later when my compressor wouldn't come on at all, turns out one of the wires i extended as part of the ECU install worked its way loose and lost connectivity. Working on fixing mine later this week.
Im wondering if there is a difference between years of SCs and how it works. Talk with Dr. Tweak though, he knows better than anyone about these harnesses.
Old 05-09-12, 03:15 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Dr. Tweak seems to be one of the genius on here for the wiring.
jinsoku3g
05-15-10 09:57 PM
JesLet
Southwest
02-03-08 04:08 PM
9secCivic
01-05-08 02:23 PM
Quick Reply: 1jz swap and air conditioning help!
