350Z trans adapter?
#77
i've since thrown the idea away for one reason. no speed sensor unless i went standalone and used an aftermarket driveshaft vss(AEM unit) which would cost another $1500+ ... to me its not worth all those costs right now
#78
I've been looking into this swap pretty seriously lately, and am extremely interested. To me the main benefit is that once the swap is done, replacement transmissions are now a fraction of the cost. And since I like to visit the track a bit, I highly foresee myself having to replace it at some point. So paying a little up front to ensure future expenses are minimized is a great investment to me.
However, what concerns me is the flywheel/clutch setup. I like to have choices, so my concern is being locked into only the specific flywheel/clutch setups 1uzswap offers, and that's it. And them being able to charge whatever they want for them. I'd much prefer to have several choices, and be able to buy them from whomever I want. I was ready to purchase this, but the clutch situation has me rethinking. Again I'd be doing this swap to minimized future expenses (meaning cheaper replacement trans cost). But if replacement clutches are going to cost an arm and a leg, well then that defeats the whole purpose.
So I'm at a crossroads on this swap at the moment now...
#80
gte & na-t
If the G35 or 350Z clutches will work on this setup i would jump on that train a longtime ago!
#82
on the first page the is a post of a member using a 350z clutch.
the clutch fits on the input spline, as long as the flywheel is larger diameter than the clutch, I can't see why it wouldn't work. in almost every trans swap across manufacturers, you always usually find people using the clutch meant for the trans and a custom flywheel. how can a 350z clutch not fit on a 350z trans?
I understand them telling you their setup is custom, theirs is definfately custom built..
That doesnt mean you cant piece together a combo that works, people do this all the time, unless im missing a whole part of the discussion here.
#83
I'm running an off the shelf mr2/toyota scion/4runner pressure plate and a sr20 clutch disc with the 350z trans on my sc400. I assume it would be easier on a 2jz since there are a few flywheel options already out there.
Check out my thread
https://www.clublexus.com/forums/sc-...from-350z.html
Check out my thread
#84
Thanks, will go through your thread. I would love to use off the shelf stuff, but I personally don't feel I have the expertise in that area to know how to piece it together. I don't like asking for help, but this is one area that I honestly would need help.
SV4double0, if you're willing to help a trans swap newb out, I'd love some help figuring this out. I'll shoot you a PM.
#85
gte & na-t
Ok so this is my last questions!
what clutch kit and flywheel do you need for JZ engines?
I am sure the 350Z flywheel will not work, someone correct me if i am wrong..If it does i will order this tyrans on monday .
I am just looking at the clutch options if you decide to go twin , triple disc later down the road.
#87
The only thing you need to bolt this on to the 2jz which is not available is the adapter plate, which no one is making yet.
Otherwise you would use the same combo as SC4double0 like the SR20 clutch w/ MR2 PP, except you would use just use a 2jz flywheel.
He had to modify a flywheel cause there is no readily available one for the 1UZ, but we have plenty for the 2jz.
Maybe if we show there is interest in a 2jz adapter they would make one, it shouldn't be very hard 2jz pattern is available to them most likely.
#89
gte & na-t
He has the 2jz/1jz adapter already , i saw that adapter for sale!
It's not that easy , you cant just use your stock flwheel with this setup trust me it's not the same, please don't waste your money yet till you get the concrete info!
Same reason why you can't run W58 flywheel when you go R154 or V160
