350Z trans adapter?
Old 06-02-15, 06:21 PM
  #571
PseudoK
PseudoK's Avatar
M10 and M12.
also all the bolts bought so far have been 10.9's that should be strong enough right? for the crankshaft bolts that hold the flywheel clutch and pressure plate in I am thinking of ordering ARP online. smart idea?
Old 06-02-15, 07:07 PM
  #572
jkpgt96
jkpgt96's Avatar
I would use arp stuff where you can.
Old 06-02-15, 08:00 PM
  #573
PseudoK
PseudoK's Avatar
from what I read 10.9 should have a tensile strength of 150,00PSi? the ARP bolts are 170,000PSI
I have these bolts on the pressure plate and the bellhousing bolts, the rest is Collins supplied, which looks like its pretty much the same stuff?
its just the flywheel bolts that I am wanting to use on it since they go under a lot or strain. if I use ARP everything this will get much more expensive FAST
Old 06-03-15, 08:47 AM
  #574
95SC3T
95SC3T's Avatar
I picked up the bellhousing and pressure plate bolts from a local fastener shop. They are all grade 10.9, the guy working there said that the metric grade 10.9 is equivilant to the grade 8 of sae bolts.
This is the size bolts collins said to get for the bellhousing. He also said to get some washers to
Use with them because some of the bolts bottom out in the adapter against the block.
M12x1.75 x 55 mm Grade 10.9
M10x1.5 x 30 mm grade 10.9
I bought 4 of each because that's what I had line up with my adapter.
Old 06-03-15, 05:46 PM
  #575
PseudoK
PseudoK's Avatar
he told me 5 of the M12 and 3 of the M10
I didnt buy the washers though
and I bought mine from ACE hardware, just like $2 a piece
the ARP bolts I bought were $35 for 10 of them
Old 06-03-15, 06:44 PM
  #576
Ali SC3
Ali SC3's Avatar
W58 in 4th, and shifter boot sitting loosely under the trim just for a rough idea of what it might look like around 32" with the gated trim.
Suprisingly I can still shift through all the gears although 1, 3 and 5 do touch the trim if you do it fast.
Don't knock my shifter boot I like red stitching =)
Old 06-03-15, 08:55 PM
  #577
Halon
Halon's Avatar
Nice man. Mine just came in the mail today too, havent opened it yet. I might try to just install it with my current shifter, but shorten my shifter horizontal piece a couple inches and see if it works. Very good find on these bezels dude!
Old 06-04-15, 03:54 PM
  #578
95SC3T
95SC3T's Avatar
I put my adapter on the trans before I installed it and I had 4 of each size line up so that's what I bought.
Id suggest everyone mount the adapter to your trans and see how many bolts you need and then go from there before you mount the trans in the car.
Old 06-04-15, 06:28 PM
  #579
PseudoK
PseudoK's Avatar
just to specify, mine is a 400, I assume your JZ
Old 06-04-15, 07:47 PM
  #580
estomax
estomax's Avatar
if you shave 5/8 off the trans the bolts you need might be shorter. this is what i used:
M12x45 – 4
M10x20 – 4
M12x20 – 4
Ali that shifter trim looks great. good idea with that, can't wait til you get your transmission in, if this works out nicely i will copy your setup
Old 06-05-15, 04:43 PM
  #581
95SC3T
95SC3T's Avatar
Yes being your 1uz and Im Jz our setups would differ.
M12x45 – 4
M10x20 – 4
M12x20 – 4
those bottom 2 you have marked M12 is M10 on my adapter. is yours an 1uz setup?
Old 06-08-15, 07:40 PM
  #582
jkpgt96
jkpgt96's Avatar
You guys seen much about welding an auto bellhousing to the cd009 bellhousing? I assume it is an a340 bellhousing but I cannot seem to find anything on it..
Old 06-09-15, 08:10 AM
  #583
estomax
estomax's Avatar
those bottom two are going through a super thing part of the bellhousing and barely do anything, M10 is probably fine too because i believe a nut goes on the other side anyway. i have a 1JZ.
as far as welding the auto bellhousing i saw a thread on some australian forum about an auto bellhousing + T56 transmission, someone selling their swap, so there is some validity to that approach but i've never seen it talked about stateside.
Marko
Old 06-09-15, 09:55 AM
  #584
jkpgt96
jkpgt96's Avatar
From what I have learned, there are guys in AUS/NZ that are doing this on the CD009, but information seems hard to come by. One company is actually casting bellhousings that are automatic bellhousings with a back end that bolts onto a CD009 once the front of the bellhousing is cut off..
http://www.trgram.com/aleks_speedtek...6129_389127867
I am working on getting more information on this from them..
Old 06-09-15, 10:27 AM
  #585
Ali SC3
Ali SC3's Avatar
man I would really like to see a better bell housing adapter option on the market. maybe one that would be short enough to allow the input shaft/clutch splines to go further in so we can use a 2jz flywheel and clutch.
I messages Collins adapters last week asking if the new no milling kit they have will work if I still want to mill the bellhousing, and received no response whatsoever, little disappointing in the communication there.
another view of the shifter, still haven't changed the bottom part for the proper seat that holds the shifter bushing, but as you can see the one I drilled out is actually working.
Moved it 1-6 and reverse.
Quick Reply: 350Z trans adapter?
