350Z trans adapter?
Old 10-10-14, 11:18 AM
  #421
PseudoK
PseudoK's Avatar
Estomax, does that one actually work?
Old 10-10-14, 12:45 PM
  #422
estomax
estomax's Avatar
yes it does,i actually took it apart again because it was an inch too far forward. The new setup will be even simpler, simply cut the stock shifter holder and put it down on posts, no S bracket needed like i welded up. Still have the weld the pivot to turn around though. i'll post more info once i get it working nicely
one side effect i did notice is that the shifter gates are slightly paralleogram instead of H pattern, gate 1 is closer to 3 than gate 2 is to 4. but that is barely noticeable.
Marko
Old 10-10-14, 01:31 PM
  #423
PseudoK
PseudoK's Avatar
well when you get it all cleaned up, have you considered selling these adapters?
Old 10-15-14, 08:11 PM
  #424
jkpgt96
jkpgt96's Avatar
EsTomax that looks pretty good! We have the same shifter placement issues in the e36 chassis with this engine and trans combo.
Old 10-18-14, 10:06 AM
  #425
estomax
estomax's Avatar
so this is what i ended up with and happy with. i forgot to take exact measurements before installing it again so i'll try to get some numbers. basically though i had to extend the u joint two inches from the sleeve that the spring pin attaches to the shifter input shaft.
Old 10-24-14, 06:01 PM
  #426
Reyke
Reyke's Avatar
I appreciate your efforts dude great idea, just needs a little finesse in the visual department. Other than that you've solved the ubiquitous "too long tranny" issue
Old 10-27-14, 07:51 PM
  #427
marco1000
marco1000's Avatar
Default shifter setup
Hey what's the actual measurement for the new setup I'm planning on putting it into a mkiv supra
Old 10-27-14, 09:21 PM
  #428
estomax
estomax's Avatar
sorry been putting off playing with the car for a bit, I took some measurements and they all ended up being right on inch marks. it is not super important to be down to the 1/16th accurate while making this, as the u joints allow lots of play. the materials can all be had at home depot too lol. 1/2 inch hollow steel rod and I think 1/2 inch square aluminum tubing.
Old 10-28-14, 05:04 PM
  #429
marco1000
marco1000's Avatar
Default trans setup
Thanks for the information I will be running one in my mkiv supra how does it drive. I think I will be buying the collins stage 4 kit
Old 10-28-14, 05:21 PM
  #430
187
187's Avatar
I was estimating around 2500 for the parts for the swap, anyone come close or under this?
Old 11-04-14, 10:44 AM
  #431
Albatross
Albatross's Avatar
did you do the MKIV 6spd tunnel swap or will you?
Old 11-04-14, 12:38 PM
  #432
PseudoK
PseudoK's Avatar
Estomax I cant work with metal at all. and with something like this I would rather buy an adapter.
Old 11-04-14, 02:18 PM
  #433
Ali SC3
Ali SC3's Avatar
remember if you have a 95-97 5 speed with the tripod shifter you already have the "6 speed tunnel" in your SC.
Old 12-15-14, 12:01 PM
  #434
UpInTheLex
UpInTheLex's Avatar
Hi All,
I just read up on this thread and I would like to add my input. Please feel free to review it, revise it, etc.
This is a running Bill of Materials needed for a CD008 or CD009 6 speed from z33 350z to 1uz sc400.
-CD009 Z33 Trans from 2005+ 350z/g35 $600-$1000
Keep factory engine/bellhousing mounting bolts!
-Collins trans adapter $300
http://collinsadapters.com/index.php...ter-plate.html
Collins trans mount $175
http://collinsadapters.com/index.php...and-mount.html
Collins pilot bearing adaptor $55
http://collinsadapters.com/index.php...g-adapter.html
Collins Clutch Release Bearing adapter $105
Collins 1 piece driveline using slip yoke from nissan titan 4x2, 1350 u joints and 4 bolt flange/saddle $450
Collins Driveshaft to diff adapter $145
Collins Tilton and PowerTrain components Twin disc clutch w/ ARP hardware $1085
Hoke shifter adapter/shift extension mod $200
Use factory Toyota Auto flex plate $ incl.
New Toyota pedal assemblies, includes MC and res $469
http://www.driftmotion.com/SC300-SC4...t-p/dm1694.htm
SS clutch line $45
http://www.driftmotion.com/Full-Leng...ose-p/dm53.htm
What length? What ends?
Lexus OEM 5 speed shift console $60
http://www.luxurymods.com/sc300shiftboot.aspx
350z Nissan slave cylinder
Speedometer Pickup:
Dakota Digital Speed Interface
SGI-5 ? $85
-------OR---------
Speed Healer
http://www.healtech-electronics.com/products/sh/
-------OR---------
Auto Meter 5289 GPS Speedometer Interface Module $170
- 3 qrts Redline MT-85 fluid $60
SC430 Diff 3.266 Ratio $150-300
So you can definitely get it all done for under $4,000 including shipping/freight and odds/ends/bits/bobs/etc.
I would say closer to $3500 depending on the price of the transmission/slave/shifter.
The source of photos is from this craigslist ad's author. Unknown.
Attached Thumbnails 350Z trans adapter?-twin_disk_clutch.jpg   350Z trans adapter?-collins_crossmember.jpg   350Z trans adapter?-1350_4bolt_adapter.jpg   350Z trans adapter?-shifter_location.jpg   350Z trans adapter?-cl_post.jpg
Old 12-15-14, 01:24 PM
  #435
UpInTheLex
UpInTheLex's Avatar
http://hokeperformance.squarespace.c...-shifter-mount
http://hokeperformance.squarespace.c...ter-relocation
This should sort out all of your shifter issues without any of this wacky-wonky-welded-hoop-a-joop craziness.
Quick Reply: 350Z trans adapter?
