Transmission jerking on sc400
Old 04-05-12, 07:57 PM
Maik04
Maik04's Avatar
Default Transmission jerking on sc400
Hey guys, just got an sc4 as a gift, it needs work but i'm will to try to fix things up. first things first, i dont know too much about cars but im a hands on type of dude.
the car has 213xxx miles, is a 94' and the tranny fluid is good. When I shift it into anything the car jerks, shifts gears fine though. Mainly jerks when I pout it into drive.Can it be my motor mounts? Something clogged up?
What are the causes of the tranny jerking? no check engine light on either.
thanks in advance.
Also, are they any vids on how to change the valve cover gaskets on these cars, or something similiar?
Old 04-06-12, 06:32 PM
Maik04
Maik04's Avatar
Bumparoooo
Old 04-06-12, 06:33 PM
chingpo05
chingpo05's Avatar
can be anything from shift solenoid to mount
Old 04-06-12, 07:00 PM
OG Dada
OG Dada's Avatar
Not a vid but this'll work; http://http://www.lexls.com/tutorials/engine/valvecover.html
If yours is an auto, problem might be a combination of throttle position sensor, tranny/engine mounts, bushings and tranny fluid. I'll post a link about the TPS when I get home, I'm on my phone right now.
Old 04-06-12, 07:18 PM
Maik04
Maik04's Avatar
Thank you so much, and yes it's an auto. If the tranny turns out bad or ends up crapping the bed, will try to convert to manual. Can maybe tightening the mounts work? If so, where are they located, sorry if i'm asking for too much
Old 04-06-12, 07:25 PM
sc101
sc101's Avatar
Change the Trans Fluid Filter i had the same problem not to long ago
Old 04-06-12, 08:13 PM
Maik04
Maik04's Avatar
Where can I get this? and how is it fro a 1-10 scale to install
Old 04-09-12, 04:31 AM
sc101
sc101's Avatar
You can get it at any auto zone or advanced auto and its fairly easy job i would give it give it a 3 or 4
Old 04-09-12, 10:09 AM
Bassrocker
Bassrocker's Avatar
mine did this and it was kinda like a sign of worse things to come when you let your foot off the gas does it creep forward quickly? also when you are going about 40mph and you let your foot off the gas does it slow down to a stop or will it just keep going?
Old 04-09-12, 10:31 AM
g4ebguy90
g4ebguy90's Avatar
Removing pan. 2/10. Changing filter, 2/10. Reinstalling pan with gasket, 9/10. lol.
Old 04-09-12, 07:20 PM
Lexus082
Lexus082's Avatar
When I changed my trans mount it made a noticeable difference. The clunking went away after I changed the mount. Then I decided to change the engine mounts as well. It idles so smoothly even with 300,000. Changing the mounts is worth the money and time. Its not too difficult either.
As for re-installing the gasket and pan to the trans, I threaded the bolts through the gasket to keep the gasket from sliding out of place while your trying to install. Not all of them just enough to keep it in place.
Old 04-09-12, 07:40 PM
bryan767
bryan767's Avatar
i could not agree with this comment one bit more. lmfao
Old 04-10-12, 11:02 AM
Maik04
Maik04's Avatar
How much is a tranny filter?
And when i take my foot off the brake it does creep forward quickly, i cant drive it yet, its not insured until next month. Should i be worried since it creeps forward quickly
Old 04-10-12, 11:08 AM
Maik04
Maik04's Avatar
When i take my foot off the brake it does creep forward quickly, i cant drive it yet, its not insured until next month. Should i be worried since it creeps forward quickly
Old 04-10-12, 10:54 PM
Bassrocker
Bassrocker's Avatar
thats what mine is doing it will just take off without my foot on the brake it will get up to 40mph sometimes 60mph wihout ever touching the gas im curerntly looking into getting it fixed but dont know where to start thinking about just taking it to the lexus dealership just to get a diagnosis because im stumped
Quick Reply: Transmission jerking on sc400
