Build Threads Details on Club Lexus SC owner vehicles
Kez's 1992 Sc300 1jz Build
Old 04-13-12, 05:53 AM
  #61
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Making progress I see.
Old 04-13-12, 05:56 AM
  #62
INTIMAZY
INTIMAZY's Avatar
Originally Posted by kez
couple of questions what did you guys block off the stock blow off valve with? or do i have to get creative and make it
I used a rubber cap on one side and machined an aluminum block off plate for the other. All ya need is a single flat piece of metal and a grinder. I put a bead of RTV around the edge to make sure it didn't leak.
Old 04-15-12, 02:20 PM
  #63
INTIMAZY
INTIMAZY's Avatar
As requested, here is how I blocked off my BOV.
Old 04-15-12, 02:41 PM
  #64
kez
kez's Avatar
Thank you sir!
Old 04-20-12, 03:15 PM
  #65
kez
kez's Avatar
Slight Update with a couple of questions. I replaced rear main seal, cam seals, and valve cover gaskets. Removed hydro water pump and basically cleaned and search for broken hoses etc.
questions of the week are as stated LOL
in the pic with valve covers i need the part number for that hose and i need a downpipe to connect to the stock y pipe with the twins. And help me verify my ECU please thanks!
Dirty before then CLEAN!
And here is that hose I need the part number to
Old 04-20-12, 03:50 PM
  #66
StiCk3
StiCk3's Avatar
for the ECU that is a Soarer/Chaser Auto ECU so you're all set there. For the hose, i found a piece of hose in the back of our parts department and modded it to fit. IDK if there is a direct replacement out there, but as long as the hose is rated for oil, tranny fluid, etc. then you should be ok. Just make sure they don't give you a hose rated for coolant (had that happen with my PS reservoir hose, swelled up and got all mushy and moist )
Old 04-21-12, 06:09 AM
  #67
kez
kez's Avatar
Ok good anything on down pipes guys?
Old 04-21-12, 09:39 AM
  #68
99SC42
gte & na-t
99SC42's Avatar
You either have to find a soarer Dp or just take the car to a shop and have them make you a pipe..finding that pipe will not be easy .
Old 05-10-12, 01:15 PM
  #69
kez
kez's Avatar
since saving some money to get harness shipped to dr.tweak i had some time to paint my ls400 bbk color might be played but i like it for now
Old 05-19-12, 09:48 AM
  #70
kez
kez's Avatar
Okay fellas question of the day before I buy this stuff. Do I need both greddy BCC and the FCC at the same time? And is anyone ran/ running a hallman pro boost controller on their stock twins?
Old 05-19-12, 10:35 AM
  #71
99SC42
gte & na-t
99SC42's Avatar
BCC= Boost Cut Controler
FCD=Fuel Cut defender
Old 06-09-12, 07:12 PM
  #72
kez
kez's Avatar
so last monday i took off the intake manifold to clean it all up and rip out the harness to get it all ready to ship it off to Dr Tweak. Question is what the heck is this in my number 6 tunnel back there?
Ohh yeah while lurking on my ebay app on the ipad i found a uncut M/T soarer harness thank god only 369.99 shipped wooooh!!
Old 06-09-12, 08:59 PM
  #73
stockhatch
stockhatch's Avatar
Nasty. No clue what that stuff is in your intake. It kinda looks like corrosion, but I don't know from what.
Regarding the bcc and fcd, you pick one, not both. Boost cut and fuel cut are two names for the same thing. I use the bcc and it works well.
Old 06-10-12, 05:37 AM
  #74
kez
kez's Avatar
thanks stockhatch on the info bout the bcc stuff.
Old 06-10-12, 06:04 AM
  #75
gerrb
Super Moderator
gerrb's Avatar
It seems to be confined to that cylinder alone. If it came from the intake manifold then , I believe all the lower runner tunnels will have same stuff. So the only place it could have come from would be the injector hole or within the cylinder. Did you do a leakdown test on the engine before you disassembled it ? If yes what was the leakdown number on #6 ? I wonder how the #6 exhaust looks like ..
I hope it is not as bad as it looks... but am sure , you will get it going ... enthusiasts make it happen !
Quick Reply: Kez's 1992 Sc300 1jz Build
