Build Threads Details on Club Lexus SC owner vehicles
Kez's 1992 Sc300 1jz Build
Old 03-31-12, 04:46 PM
  #46
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Looks like a great project build man. I am subscribed. Check out mine in my signature!
Old 03-31-12, 04:55 PM
  #47
stockhatch
stockhatch's Avatar
Chaser fo sho. I hope you got that motor cheap because you have plenty of extra wiring, sump swapping, pump and fan swapping to do. Good luck with it sir!
Old 04-01-12, 03:25 PM
  #48
Luv2xl
Luv2xl's Avatar
ECU wiring will be fine...
Good luck wih the install. Don't cut corners and replace the seals, maintenance items... Good luck!
Old 04-01-12, 03:56 PM
  #49
INTIMAZY
INTIMAZY's Avatar
Is that a 300zx I see in the background? It looks like a good candidate for swap
Old 04-02-12, 08:29 AM
  #50
kez
kez's Avatar
Originally Posted by JDMb16bEG6
Looks like a nice build bro, I'm in the process of gettin my 1jz vvti prepped for my sc, if you need a hand let me know I'm right across the bridge in morrisville
Are you they pep boys guy?
And yes it is a 300zx after the 1jay is swapped over the old 2jz-ge will be the new heart of the Z Na-t of course. And I'll prob put the daily 1988 300zx in garage restore that baby
Old 04-02-12, 03:51 PM
  #51
megamax
megamax's Avatar
well i got the exact same motor swap from engine depot. and yes yours is from a chaser..
Old 04-02-12, 04:13 PM
  #52
JDMb16bEG6
JDMb16bEG6's Avatar
Lol yup pep boys bro, I think I remember you, black sc, did you auto to manual swap, then did a head gasket?
Old 04-02-12, 05:06 PM
  #53
kez
kez's Avatar
yeah you'll be getting pm's
yupp that's me
Old 04-02-12, 07:03 PM
  #54
JDMb16bEG6
JDMb16bEG6's Avatar
Originally Posted by kez
yupp that's me
That's what's up bro, let me know if you need a hand, I'm still in the process of collecting parts and extending the harness, I was lucky enough to get a 1jz vvti out of a soarer, let me know bro, always down to work on an sc
Old 04-08-12, 10:13 AM
  #55
kez
kez's Avatar
Little baby update ive been doing alot of research but oil pans are off until my package comes from driftmotion
couple of questions what did you guys block off the stock blow off valve with? or do i have to get creative and make it
Old 04-08-12, 11:41 AM
  #56
StiCk3
StiCk3's Avatar
^^ If you know how to weld or know someone who does, you can cap off the old BOV holes. i talked with a guy at work who does welding on the side, he said he could weld the old BOV holes shut on mine no problem. Will be going this route later in life
Old 04-08-12, 03:29 PM
  #57
meangreen1
meangreen1's Avatar
You should do the rear main while its open.
Old 04-12-12, 02:17 PM
  #58
kez
kez's Avatar
I'm looking at the oil drain neck in the last pic. Does this mat directly to my 2jzge rear sump oil pan?
Old 04-12-12, 03:16 PM
  #59
StiCk3
StiCk3's Avatar
^^ it should, but remember you need to drill out your old 2J pan and tap the two bolt holes on the upper portion of the pan. Should work though
Old 04-12-12, 11:27 PM
  #60
levie
levie's Avatar
subscribed, good luck!
Quick Reply: Kez's 1992 Sc300 1jz Build
