First check engne light (code 25) then trac light comes on
Old 06-08-14, 06:32 PM
mmartin888
mmartin888's Avatar
Default First check engne light (code 25) then trac light comes on
Hey guys its a 92 sc400. The car drives and idles fine but after about 5 miles the check engine light comes on then the trac light. I pulled codes it is 25 but no trac code. It seems to drive fine. Any ideas where to start. thanks Mike
Old 06-08-14, 08:11 PM
oldManTan
oldManTan's Avatar
Main o2 sensors. here's the ones i used, and i also found is a code that gets yout 20% off your first order from sparkplugs.com might as well buy some more stuff while you're at it.
go to autozone and get an oxygen sensor tool, they give you tools for free, you pay upfront then return it and get your money back, get some pb blaster cz they'll be baked pretty well in there, spray it, let it sit, make sure all the engine parts are cool too, then take the sensors out, use the awesome crimps that come with the kit and put the old plugs on the new sensor. the kit comes with great directions and tell you everything you need to do. code rid of my code 25, car uses a little less gas now and no more weird odor.
code: RRWEB14
StiCk3
04-26-08 05:40 AM
gurjot
02-07-08 10:13 AM
nicos1
10-08-07 12:44 PM
AME_VIP
02-03-06 04:27 PM
TomWahjudi
03-01-03 03:52 AM
Quick Reply: First check engne light (code 25) then trac light comes on
