Greddy oil relocation kit 2jzgte...installed pics?
Old 03-26-12, 06:20 PM
97-SC300
97-SC300's Avatar
Default Greddy oil relocation kit 2jzgte...installed pics?
Hey guys,
Wondering if anyone has any pics of where they installed their oil filter using the Greddy oil relocation kit on the SC?
I got my kit and basically looking for any ideas. Haven't had the chance to look under the hood yet, but will shortly.
Thanks
Old 03-27-12, 07:44 PM
gadgetSC
gadgetSC's Avatar
Here is a pic, you can see where the filter bracket mounts to one of the
upper oil pan\bellhousing bolt holes.
Old 03-28-12, 08:45 AM
Dms3603
Dms3603's Avatar
Does it make a different mounting this higher in the engine bay?
Old 03-28-12, 12:05 PM
97-SC300
97-SC300's Avatar
Awesome! Thanks so much Gadget!
Old 03-28-12, 12:27 PM
gadgetSC
gadgetSC's Avatar
You're welcome
Old 03-28-12, 12:32 PM
gadgetSC
gadgetSC's Avatar
I have seen them mounted where the battery or fuse box would go when some install a front facing
intake. I installed it this way.....I can reach under the car and change the filter, easier to access than the oil pan bolt.
Old 03-28-12, 01:51 PM
Luv2xl
Luv2xl's Avatar
Gadget.. Do you have a better shot as to how that bracket is mounted on the oil pan/bell housing?
I cant picture it...
Old 03-29-12, 09:11 AM
gadgetSC
gadgetSC's Avatar
Thats the best one that I have right now. If you can try to look closer in the above pic, there are 2 bolts
at the very top of the silver assembly holding a black mounting bracket that will have 1 bolt hole to mount to the bellhousing. Hope that helps.
Old 03-29-12, 09:43 AM
Dms3603
Dms3603's Avatar
cool thanks for the response.
Old 03-29-12, 09:49 AM
Luv2xl
Luv2xl's Avatar
Excellent! I notice it now.. I assume the bracket doesn't interfere with anything?
Old 03-29-12, 10:11 AM
gadgetSC
gadgetSC's Avatar
No interference problems. The bracket is small and has only one bolt hole as mentioned, so it will
flex a bit if you have your filter on super tight. Not a big deal if you brace the mount with one hand and turn the filter with the other.
Old 06-26-12, 09:15 PM
jgdynamics
jgdynamics's Avatar
are the greddy parts able to be fitted to a 1jz? i assume the thread on the stock filter housing is the same, right?
Uda880
1Gen RC350 / RC-F Classifieds
01-05-18 11:01 AM
breed
SC400 / 300 Classifieds
02-27-13 08:56 PM
DanozLS430
05-27-07 09:57 AM
Streamline
09-26-05 05:55 AM
kodai
Performance
15
04-01-03 10:34 PM
Quick Reply: Greddy oil relocation kit 2jzgte...installed pics?
