leaking R154
Old 04-03-12, 07:45 PM
meangreen1
meangreen1's Avatar
I would like to know too.
Old 04-03-12, 07:46 PM
meangreen1
meangreen1's Avatar
Originally Posted by Quicksc4
Here you go
I see the vnet on the one pic but not the other. Anyone have pics of the vent on a Mk3?
Old 04-03-12, 07:48 PM
silver z
silver z's Avatar
Originally Posted by stockhatch
I wish one of you guys with a leaker would put the car on a dyno and see if it still leaks. If its a frothing/windage/vent issue, it will leak on the dyno. If its a shaft deflection/g-related pooling issue, it probably wont.
A group of us are wanting to hit up the dyno but i didnt want to be blowing fliud all over ya know. With mine, after a couple hours of driving and casual beating the under side of my car is all gear lube!! from the tailshaft to the mufflers.
I can clean it up and try it next week
Old 04-03-12, 07:53 PM
99SC42
99SC42's Avatar
MK3 doesn't have a Vent
Old 04-04-12, 04:53 AM
stockhatch
stockhatch's Avatar
It vents at the output shaft seal
Old 04-04-12, 06:59 AM
99SC42
99SC42's Avatar
Lol I KNOW , i was just saying that it doesn't have the breather like the chaser R154, that's the pics he was asking for.
edit, No they vent at the shifter.
Old 04-04-12, 01:30 PM
Ali SC3
Ali SC3's Avatar
maybe a larger breather needs to be installed since you are running much more horsepower than was ever intended on this trans. I would look into drilling and tapping somewhere for a large AN fitting and put a breather filter on it. If pressure builds up, oil will leak eventually no matter how much RTV is involved.
Old 04-04-12, 03:55 PM
meangreen1
meangreen1's Avatar
Lol i know , i was just saying that it doesn't have the breather like the chaser R154, that's the pics he was asking for.
Well if the chaser has one and not the MK3 then I think it doesnt matter. If it did then you would see a lot more threads about this.
Old 04-04-12, 05:30 PM
INTIMAZY
INTIMAZY's Avatar
Is it definitely a pressure problem? What would the pressure originate from? windage? I'm just throwing an idea out there, could it possibly be deflection of the output shaft?
I had an oil leak out of the output shaft seal last year and replaced the seal with a W58 seal. It works for now. I never pushed crazy horsepower numbers so why mine failed so prematurely is a puzzle to me.
Where exactly would be the best place to drill a breather?
Old 04-05-12, 09:01 AM
99SC42
99SC42's Avatar
I edited my post #21
These transmissions breath or vent at the shifter Not the Output shaft..
Old 04-05-12, 01:57 PM
stockhatch
stockhatch's Avatar
^^^^LOL I was making a joke bro. They certainly aren't SUPPOSED to vent at the output, they just DO :P
Old 04-05-12, 02:07 PM
99SC42
99SC42's Avatar
No i really thought you were serious Lol , And i didn't even catch it haha.
Old 04-09-12, 05:29 AM
silver z
silver z's Avatar
well i tryed somthing..... im sure you will laugh just as i did but i was willing to try anything.
In one of my many nights or searching why this happens to some and not others it seems, i read one guys fix and tryed it.
my shifter extention is 5" long and with a few things combined "higher hp, more pressure, maybe pooling in the extention" i acually took 2 sponges and lined the shifter extention with them tight against the shift rod. Funny i know and i never thought it wold work but after a few days of 20+psi + hole shots its around 97% better, still weaps but is not like a waterfall!! i can live with it. Half tank of gas beating the hell out of it and the next day there was a quarter size drop on the ground vs the hole underside of my car.
the sponge will just saturate and let the fluid drain back down in vs blowing out the shifter, even if it does fall down in the trans......its a sponge, it wont hurt anything.
Old 04-09-12, 06:46 AM
spoolxexo
spoolxexo's Avatar
Here's is something to consider:
My R154 is F@#$ed. I mean really screwed.
I can measure Input/output shaft deflection around 1/4". Yes it's that bad. It whines, and crunches, and...
Is it possible, that even in a perceived "Good R154" has enough output shaft play to distort the output seal?
Higher HP deflects the shaft more = more seal distortion.
The R154 has a "Rock Crusher" nickname, but do you think we are just leaving the shaft play alone, because "It's a Toyota R154" and we just assume that it will hold?
I mean, that's what I did after the research.
Old 04-09-12, 07:36 AM
99SC42
99SC42's Avatar
^^^^ Are you serious?
But per toyota all the manual trans shaft should have some kind of play, but i am not sure if it's 1/4".
FML!! I was selling my car to this local guy, and he couldn't afford the car with the V160 .So he asked me to install the R154 in there and lower the price So" i said deal"
Last week he backed out of the deal, and i already sold my V160 because i can't find any decent deal on 6 speed swap and i have to deal with leaking R154 BS
Quick Reply: leaking R154
