Differential Bushings - new product
Old 08-14-14, 10:56 AM
  #61
Halon
Halon's Avatar
It's the diff ear bushings on their site. They look a bit different then these ones though.
Halon is offline
Old 08-20-14, 01:03 AM
  #62
stephenb
stephenb's Avatar
Originally Posted by aliga
no more bushings in stock, we have a new batch of 10 being made.
Please post up if you want a set. 140 shipped, and I can contact you once they are produced. Thank you.
I would like a set please! Do you also make the horizontal bushings, the ones on the rear of the diff?
stephenb is offline
Old 09-24-14, 11:02 AM
  #63
MVsGS300
MVsGS300's Avatar
My rear differential thuds when j go from Park to Drive. It also thuds when I punch it from a roll. I was wondering if these bushings will fix that problem or do I need to replace my differential?
MVsGS300 is offline
Old 09-24-14, 08:48 PM
  #64
Halon
Halon's Avatar
Quick update that I have the FIGS ones installed for awhile now and so far so good.
Halon is offline
Old 12-08-14, 03:54 PM
  #65
Reyreyd1
Reyreyd1's Avatar
Default 2001 Lexus is300
Want to know if you still have the upper differential bushings available?
Reyreyd1 is offline
Old 08-12-15, 03:38 AM
  #66
Studiogeek
Studiogeek's Avatar
Any more of these?
Studiogeek is offline
Old 08-12-15, 04:13 AM
  #67
Biddles
Biddles's Avatar
Anyone have the Toyota Part Number?
Biddles is offline
Old 08-04-16, 08:34 PM
  #68
Champa99
Champa99's Avatar
For you guys who don't make it to the classifieds section, we have a new product, details below:
5 Sets available, 120 shipped. paypal info is in the sig.
This has been a quest of mine for over 1 year as these need to be replaced/upgraded in almost all Toyota mkiv supra's and Lexus SC300/400 and GS300/400 because when the very soft rubber of the stock bushings flexes under torque/load of the drive line it causes the differential to change positions and return to the normal mounting position rapidly which in turn causes dreaded driveline breaking wheel hop which is where these bushings come in to play as they replace the soft rubber stock bushings.
I was looking all over the earth for poly bushings to replace the stock ones to no avl which until now only solid aluminum bushings were avl for more than double my price and if you are like me solid bushings are just not going to cut it on a street drivin car so look no further here is your solution!!
I will say that when I installed them in my own car which is daily drivin the difference was night and day as the wheel hop is totally gone as well as a "diff clunk" I had been chasing for quite some time when taking up a drive gear from a cold start/high idle.
People often ask me how would I sum up the feel with these installed to which the best most reasonable answer I have would be... It feels like the car picked up 15whp down low in the powerband as it totally transforms the feel of the car with a much more connected feeling with out the harshness or vibration caused by that of a solid bushing.
Price for the xspsi6 poly rear differential bushings are 120.00 shipped in the USA.
do you have any more ???
Champa99 is offline
aliga
SC400 / 300 Classifieds
110
12-27-18 06:51 PM
aliga
34
07-14-14 06:22 PM
aliga
33
02-26-12 05:18 PM
aliga
01-29-12 08:10 PM
en11871
02-26-08 08:27 PM
Quick Reply: Differential Bushings - new product
