Odd Rear end diff pop noise. Brake noise
Old 02-11-12, 01:38 PM
CAsc300
CAsc300's Avatar
Default Odd Rear end diff pop noise. Brake noise
Hey guys so i have been having this problem with my sc. its a factory 5 speed. so when i go to take of or slow down quickly i get a bad pop noise comming from the right rear side from the inside sounds like its comming from the wheel or hub. but olny when im giving it aloat of torque not from braking. i have a wheel stud missing and i thought this could possably be the wheel moving around but thats highly unlikly i think "replacing today". could it be the diff or something im not shure where to start.
and another issue is when i bought the car they guys just spray painted the front calapers and caused it to squeal like no other and its very irratating. from 5mph+. im not shure where to start on these problems and could realy use some help. suggestions?
Old 02-11-12, 02:55 PM
WadeLovell
WadeLovell's Avatar
Calipers - remove one of the offending calipers and check the installation of the pads, etc. Make certain the little springs are where they should be. Then apply anti-squeal to the back of the thin metal backing plate that fits on the back of the pads. Reassemble and check for improvement before doing the other side.
Old 02-11-12, 02:56 PM
WadeLovell
WadeLovell's Avatar
Pop under rapid acceleration - pull the right rear wheel and check the wheel bearing. repack it even if it looks perfect.
Old 02-11-12, 05:20 PM
CAsc300
CAsc300's Avatar
Thanks guys will start there. i feel like a noob once more lol.
Old 02-12-12, 09:58 AM
RyanV
RyanV's Avatar
Could be one of the control arm bushings back there so check those or have a susp shop check them out.
Old 02-18-12, 01:28 PM
CAsc300
CAsc300's Avatar
it sounds like plastic snapping in half. when ever you accel or decell fast not when breaking.
badteddy
Suspension and Brakes
09-16-14 09:20 AM
Nosexnolex
07-25-12 02:57 PM
calichris
09-05-07 06:45 PM
jsconiers
04-22-07 11:39 AM
Quick Reply: Odd Rear end diff pop noise. Brake noise
