92 SC300, Cold Start Chatter
Old 02-04-12, 02:28 AM
AnonymousG
AnonymousG's Avatar
Default 92 SC300, Cold Start Chatter
I have a 92 SC300. Car has 160K on it.
Recently when I start it in the cold the car would make a chatter sound or what sounds like chatter. When I first start it for couple seconds then it goes away. It also happens when I accelerate at WOT or under hard acceleration.
What could it possibly be?
Could it be my belt tensioner bearing going bad?
Thanks and appreciate the help.
Old 02-06-12, 01:49 PM
AnonymousG
AnonymousG's Avatar
any help or ideas?
Old 02-06-12, 02:12 PM
scoobySC3
scoobySC3's Avatar
Would it be possible to take a video or sound clip of it? Could be anything from valve tap to piston slap or a bunch of other things. Also may not be a bad idea to pop the hood before you start it in the morning, and either have a friend start it, or start it and jump out to try to pinpoint where the sound is coming from. You can also take off the top timing cover and look for any irregular marks on the timing belt, generally a bad idler or pulley will create odd wear on the belt.
Notice any smoke from the exhaust during WOT?
Thanks,
Rick
Old 02-06-12, 02:34 PM
LEX_MAN
LEX_MAN's Avatar
Mine does that too, been doing it for 2 years now. When you start it goes CLACK CLACK CLACK and goes away ?
Its probably bearings not getting oil fast enough.
Old 02-06-12, 03:27 PM
AnonymousG
AnonymousG's Avatar
I
Thanks,
Rick
'll check the timing belt when I get home. I'll also do that other tip also.
Only smoke that comes out of the car is when i first start it, but I also have the 12v mod, so i dont know if it would make it smoke either. and the smoke goes away after its warm.
thanks
Did yours only do it when you first start the car?
My car has the chatter at start when cold, at WOT, along with hard acceleration. But doesnt do it when the car is idleing or crusing.
Old 02-07-12, 12:24 PM
AnonymousG
AnonymousG's Avatar
I didnt get to check the timing belt, since I misplaced my HEX set.
But i did have someone else start it when I was outside looking at the engine.
Is it normal for the serpentine tensioner to shake on first start up?
Old 02-08-12, 02:13 PM
WadeLovell
WadeLovell's Avatar
No, it is noy normal if I understand your description. The bearing for the tensioner may be shot.
Old 02-08-12, 02:14 PM
WadeLovell
WadeLovell's Avatar
Sorry "not" normal. Small phone keyboard ;
Old 02-09-12, 10:38 PM
chingpo05
chingpo05's Avatar
tensioner bearings make a whining noise when bad and will progress with speed. is your car sitting for long before the cold start? is it making noise from upper or lower part of motor, also front or rear
Old 02-10-12, 04:48 PM
WadeLovell
WadeLovell's Avatar
Stethoscope may be helpful.
Old 02-10-12, 06:52 PM
AnonymousG
AnonymousG's Avatar
I think the bearing is shot, when my car starts the tensioner moves and rattles until it gets steady, and when i rev the engine the tensioner moves quite a bit.
the car is sitting anywhere from over night to only an hr. its making it from the front.
Old 02-10-12, 08:38 PM
SexCoupe
SexCoupe's Avatar
remove the serp belt then turn the car on see if it makes the noise still
Old 02-11-12, 07:20 PM
AnonymousG
AnonymousG's Avatar
So, I was wondering would it be ok to just change the serp. tensioner pully with a new one? Autozone sells a new one with a bearing for $20.
Old 02-16-12, 02:20 PM
AnonymousG
AnonymousG's Avatar
So the noise is still there but not as noticeable, I'm going to be doing some maintence stuff to see if it helps.
I'm pretty sure the acceleration rattle is from the heatshields, since when i looked under the exhaust was bent.
Old 01-01-13, 11:51 PM
Ill92SC3
Ill92SC3's Avatar
sorry to bring up an old post but would just getting the 20$ tensioner pulley work the same as if i get the whole tensioner? i just need to replace the bearing not the whole tensioner but autozone doesnt sell the bearings alone.
Quick Reply: 92 SC300, Cold Start Chatter
