Cylinders full of fuel...HELP!!!
Old 12-31-11, 09:51 AM
BigSticks
BigSticks's Avatar
Default Cylinders full of fuel...HELP!!!
I have a 1993 stock SC300 that I have lost two engines due to cylinders filling with fuel.
I purchased the car with a blown head gasket and had it replaced...Vehicle would not crank after repairs.
Discovered number two and three cylinders and intake runners full of fuel.
Installed a used motor and drove vehicle 78 miles...Vehicle died and would not restart.
Found number five and six cylinder along with intake runner full of fuel.
I did not re-use any injectors or the fuel regulator from the first engine so I have ruled out that problem.
I also did a 12 volt conversion after I lost the first engine to bypass the fuel pump ecu.
I am suspecting I have a bad ECM. Is this correct?
Old 12-31-11, 11:49 AM
nivek5sfe
nivek5sfe's Avatar
most likely a bad ecu. usually when they go bad they leave the injectors running wide open.
if you want to, take the ecu out, open it up and look for busted/leaking capacitors. if there are any visible then thats the culprit.
Old 12-31-11, 12:40 PM
greens14
greens14's Avatar
im with ^ on saying check ecu. are you throwing any codes also/running rich etc?
Old 12-31-11, 02:35 PM
BigSticks
BigSticks's Avatar
Thanks...I will check the ecu.
meetoo1
GS - 1st Gen (1993-1997)
10-29-12 02:07 PM
bighead222
SC- 1st Gen (1992-2000)
07-09-11 02:41 PM
SC400-V8
16
03-01-04 04:35 PM
The Ikon
08-31-01 11:03 AM
Quick Reply: Cylinders full of fuel...HELP!!!
