Shift hesitation sc400 tranny
Old 11-25-11, 02:36 PM
ArTofSoaR
ArTofSoaR's Avatar
Default Shift hesitation sc400 tranny
Replaced the fuild, filter and shift solenoids in my 92 and i'm STILL having shift issues. Any ideas what else can be giving me headaches?
Old 11-25-11, 03:01 PM
SexCoupe
SexCoupe's Avatar
Transmission cable or transmission mount
Old 11-25-11, 03:57 PM
ArTofSoaR
ArTofSoaR's Avatar
Why would the cable be an issue, i've never had a reason to adjust it. I replace my solenoids and changed my oil because it was clunking into gear then finally shifting like crap all together. Now it shifts a tad better but with hesitation into 1st AND reverse
Old 11-25-11, 04:00 PM
xspsi6
xspsi6's Avatar
These are for sure the 2 most common issues that can cause this.
Old 11-25-11, 04:51 PM
ArTofSoaR
ArTofSoaR's Avatar
Ok since i've eliminated the solenoids as a issue, I'll check the cable/ mount. Is it a matter of adjusting or replacing?
Old 11-25-11, 06:45 PM
xspsi6
xspsi6's Avatar
These mounts tend to go bad quickly in these as they are way soft and the cable controls line pressure in the trans so adjusting it to up the pressure will help hopefully.
Old 11-25-11, 06:49 PM
SexCoupe
SexCoupe's Avatar
it should be adjusted to the far right(driverside fender)1-2 mm from the end of the threads...where in GA are you?
Old 11-25-11, 08:05 PM
ArTofSoaR
ArTofSoaR's Avatar
Ok thanx guys i'll give it a try come the morning. Its just weird having the motor over rev like it does. Feels like slipping gears. Hopefully this does the trick.
I'm in duluth btw SexCoupe, how abt you?
Old 11-25-11, 10:42 PM
chingpo05
chingpo05's Avatar
there is a cable that is connected to throttle body going to tranny, tighten this. what fluid did you use? hopefully not autozone stuff
Old 11-26-11, 06:28 AM
SexCoupe
SexCoupe's Avatar
i am in norcross lol go figure lol i PMed you
Old 11-28-11, 04:13 PM
ArTofSoaR
ArTofSoaR's Avatar
I used toyota tran fluid.
Sad to say tho even after adjustment the prob still remains. Adjusted nuts to the end of the cable with no positive results.
Heres where I adjusted it to. The metal stopper (not in this pic) isnt at all close to the end of the cable. The cable is also still slacked a bit. I'm not familiar with toyota auto trannies but i'm almost certain the slack should've been taken up some.
Old 11-28-11, 04:58 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
There's always this........ https://www.clublexus.com/forums/per...-shifting.html
Old 11-28-11, 06:23 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
OLT comes through again..
ArTofSoaR
ArTofSoaR's Avatar
Hmm i'll give the TPS a try. Along with checking the suggested mount.
Old 11-28-11, 06:24 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Might help, might not.... thread says a lot of people benefited from it.... dunno if it is your issue or not. It may help you track your issue to a bad TPS or IAC however. (which is where I'd put my money on a hunch)
Behemoth7
05-31-14 05:34 PM
ajmccarrel
20
05-28-14 02:45 PM
MdSC400
11-21-10 09:52 PM
818_sc4
01-30-10 05:21 PM
Mr Johnson
Performance
18
04-21-05 06:38 PM
Quick Reply: Shift hesitation sc400 tranny
