Please help! Changed slave cyl. black fluid & no pressure
Old 11-19-11, 10:55 AM
theory5150
theory5150's Avatar
Default Please help! Changed slave cyl. black fluid & no pressure
My old slave cylinder was leaking so I got under the car and changed it. Then I replaced the fluid that had leaked out when the slave was off the trans. Then proceeded to pump the clutch to build pressure. The pressure wont build (nothin' leaking) and the fluid in the master cylinder is completely black Can anyone help me?
theory5150 is offline
Old 11-19-11, 11:08 AM
theory5150
theory5150's Avatar
Also, went to bleed the system and the nipple unscrewed wont allow the fluid to come out...
Old 11-19-11, 11:17 AM
BoostAddct
BoostAddct's Avatar
Sounds like there has to be a clog somewhere if you aren't get fluid out of the slave bleeder nipple. You will need to bleed the slave cylinder since you replaced it with a new one and air definitely got in the lines. I've never seen black fluid personally though.
BoostAddct is offline
Old 11-19-11, 03:01 PM
theory5150
theory5150's Avatar
Thanks man, anybody else experience this problem or anything like it?
Old 11-19-11, 07:05 PM
BenStoked
BenStoked's Avatar
Do you still have the old one? Install that one, see if you can bleed that one. even if it's leaking, it will rule out a dud replacement.
the fluid is black, because it needs to be replaced.; it's old and contaminated.
BenStoked is offline
Old 11-19-11, 07:14 PM
chingpo05
chingpo05's Avatar
are you doing the 2 man bleed?
chingpo05 is offline
Old 11-19-11, 07:18 PM
k7q
k7q's Avatar
maybe a big air pocket. bleed again?
k7q is offline
Old 11-20-11, 11:21 AM
theory5150
theory5150's Avatar
Huge air pocket and I hate to admit it but I was trying to bleed it alone which is why : .. Had to recruit my dad to help lol Thanks everybody for the help, please close thread mods
Old 11-20-11, 11:22 AM
BoostAddct
BoostAddct's Avatar
Glad to hear it...2 man bleeding always helps.
Old 11-20-11, 01:43 PM
iridebmx
iridebmx's Avatar
2 men 1 nipple
iridebmx is offline
Old 11-20-11, 04:02 PM
jadu
live.love.laugh.lexus
jadu's Avatar
done.......
jadu is offline
theory816
Hybrid Technology
07-20-16 06:03 PM
cwolaw
06-02-14 08:53 PM
chenxingha
RX - 1st Gen (1999-2003)
09-22-08 05:01 PM
Quick Reply: Please help! Changed slave cyl. black fluid & no pressure
