Battery dies intermittently
Hey everyone. I just got my first car and it's an sc400. I am in love with this car but there's one major issue i'm having (along with a bunch of minor ones.) So far this has happened 3 times. I put the key in the ignition, the steering wheel lowers, i turn the key and all of the electronics completely die. the car doesn't make a sound and all of the lights go out. To fix it i pop the hood and jiggle the battery and everything fires right up. The battery is new (sticker says august 2011) but the thing is it isn't strapped down and it looks like its too small for the battery compartment. Could either of these be the issue? Any help is appreciated.
thx for the suggestion, just went out and checked and one of them was a tiny bit loose. IDK if it was enough to make a difference but hopefully it did and it wont happen again. srry im a total noob with cars
What it is - The tiny connection made by the loose connector is enough to power a few things because that small connection can flow just enough amps to move your steering wheel and turn on a light or two, but apply anything else and the voltage drops too low. This is just one reason why the connection is almost a complete 360 around a battery post. Tightening it up will definitely fix most of the problem, as far as the battery being too small, verify the part number from where it was purchased with what they recommend as a replacement. The SC400 as far as I know has a few different groups of batteries that can be used. And you really should get it strapped down, flying and exploding batteries are never a good thing.
i think we all have had a problem like this before, i had to wiggle some things around when i was doing my fmic install, i was 16 at the time as well and i forgot to tighten up the battery, and i thought my car was in serious trouble, so i take it home and kinda just checked everything, and of course the last thing i check is my negative terminal and i could pull it off with my hand without touching the bolts. Anyways was that all of your problems man?
HELP A BROTHA OUT!
