Converting to 5SPD - Question
Old 11-09-11, 05:03 PM
TechGreek
TechGreek's Avatar
Question Converting to 5SPD - Question
So, there's a 93 5 Speed in the junkyard here locally with a transmission that feels great. However, someone pulled the ECU. I've got the cluster already, and I've already drilled the hole for the clutch pedal to use for my amp power wire.
If I go to the junkyard, what all will I need so far I have this
1) Transmission, Clutch, Flywheel
2) Pedal + Reservoir, Brake Pedal
3) Drive Shaft
Do I need both sides of the drive shaft? Will it connect to my auto pumpkin in the back? I've got an automatic ECU but I do have a five speed cluster already installed.
Will I need any harness connectors?
Thanks guys, it seems to be harder finding an ECU for the A/T right now and I know I can get this quickly and time is of concern.
Yes, I've searched but there is no concrete DIY that I could see.
Thanks,
Tech
xspasprox
Florida Lexus Club
10-22-10 11:00 AM
TurboGS
SC400 / 300 Classifieds
02-17-09 05:47 AM
mteele
20
09-21-08 01:47 PM
silviaguy
06-17-08 08:47 PM
technol
05-27-05 08:46 PM
Quick Reply: Converting to 5SPD - Question
