P/S problem
P/S problem
I'm a newbie at this stuff and am not overly familiar with the language. '97 SC400. When the car is running the p/s reservoir bubbles over as though it were boiling. I've replaced the air control valve but no changes. My "backyard" mechanic suggests that it "might" be the rack & pinion which I'm willing to purchase if there is some support from this site for that kind of expenditure. Any thoughts are welcome.
ThreePutt2
ThreePutt2
has the power steering system been opened at all recently? there could be air in the system. Follow the procedures to properly bleed your p/s system, see if that provides any results. If you're still experiencing the same issue, you might have a bad rack. That isn't all that uncommon with these cars, especially higher mileage ones. Also, with the engine running, turn your steering wheel to full lock, do you hear the pump whine a bit? If not, you could also have a bad pump.
jdub20tx
Performance & Maintenance
08-08-12 06:29 PM
Sportznuts
04-29-07 11:53 AM
