Strange smell under boost/not hitting target boost
I have a 2jzgte swapped car usdm tubos I purchased from someone on this board, so I don't know all the ins and outs. I've been noticing that when under boost the car emits a strange, somewhat sweet smell. And it only happens under boost. Not sure if it's coolant. The car isn't over heating. There's no white or black smoke from the exhaust. I had a leak down test done on the engine not too long ago with no ill results.
And I'm having a hard time seeing 17psi. I have a hallman mbc and when I try to turn it up the more difficult it seems to make boost. Could these two issues be related?
I have to admit I have not checked the coolant level in this car yet. I'll have to check where the levels are in the morning when everything isn't scalding hot.
I filled the overflow tank to the line with coolant and after a few weeks of driving the bottle is empty again. So there is a coolant leak somewhere. If its at the turbos, do I have to remove the turbos to fix it?
1JZ Single SC400
Depends on where the leak is at. To reach the back side of the motor or under the stock twins you might have to remove them. Try and run your hand along the plumbing and see if you can detect it.
Adam0412
01-25-13 12:16 PM
