Tweak'd Performance 2JZ-GTE SC300 Engine swap
Old 10-01-11, 11:12 AM
  #31
RyanV
RyanV's Avatar
Looks like your almost done!
I have the same clutch, and my is pretty noisy. Doesn't like to slip without making noise, and now the clutchdisc springs rattle, only with the A/C on. I think the rattle is mainly due to the Findanza flywheel I used...you'll probably be fine with the stock flywheel.
Old 10-03-11, 05:46 AM
  #32
TweakTech
TweakTech's Avatar
Originally Posted by luvmysc400
Nice build, so the w58 bolts right up no with no mods?
Yes, I did not change a single thing on the W58 aside from installing a new bearing
Originally Posted by Vwpride12
That's looks like vibrant reinforced silicone hoses, it's made for temps up to 350. Should be good.
You have a very good eye, sir!
Old 10-03-11, 05:47 AM
  #33
97-SC300
97-SC300's Avatar
any updates?
Old 10-03-11, 06:12 AM
  #34
TweakTech
TweakTech's Avatar
Originally Posted by 97-SC300
any updates?
Yes, the car itself is basically done. The only thing left is fill with fluids and pre-start, which I will be doing this afternoon. I will work on getting some more of the pictures posted today as well!
Old 10-03-11, 06:23 AM
  #35
TweakTech
TweakTech's Avatar
After the engine was bolted into place Dr Tweak started building a custom harness on the engine, while it was in the car.
Old 10-03-11, 07:29 AM
  #36
97-SC300
97-SC300's Avatar
Awsome work guys, harness looks amazing. Cant wait to get mine back
Old 10-12-11, 10:46 AM
  #37
97-SC300
97-SC300's Avatar
any more updates on the swap? more pics? pics of tru-boost installed?
Old 10-14-11, 06:55 AM
  #38
TweakTech
TweakTech's Avatar
Sorry guys, I've been so busy working out the bugs with the SC I haven't been keeping the thread updated. I'll see if I can't get some more pictures up soon. The car has been out for a few test drives. Had a rear main seal leak, fixed that, then P/S pump went out, replaced that, now we're experiencing an insane over boosting issue. Aside from that, the thing pulls like a raped ape all the way up to boost cut
Old 10-14-11, 07:18 AM
  #39
stockhatch
stockhatch's Avatar
Looks good sir! Are you sure it is hitting boost cut and not the dreaded Aristo neutral rev limiter? I fought that same issue thinking it was boost cut until I put a boost gauge on it and saw it was only making 11psi.
Old 10-14-11, 07:47 AM
  #40
TweakTech
TweakTech's Avatar
Yes. we have an AEM Tru-Boost gauge on the vehicle. Currently it's only functioning as a boost gauge. We do not have the solenoid hooked up yet. We are consistently hitting boost cut at 17~18psi. Then the ECU goes into low boost mode and won't let us boost over 4~5psi.
Old 03-15-12, 04:43 PM
  #41
Valcoor
Valcoor's Avatar
any more update? I want to do the exact same swap on my 92 sc300. can you post a complete parts list and how much do the wiring harness run?
Old 03-18-12, 02:17 PM
  #42
TweakTech
TweakTech's Avatar
I'm sorry guys, I've been insanely busy at work with two new employees, and new projects for 2012! I'll try and finish posting all the pictures I have of this swap. The car went home (back to Colorado) back in October, then a few weeks after that I was in an accident with my personal SC300, so my presence on CL wasn't as often.
To Valcoor, for pricing information, please send me a PM, we are no longer vendors on these forums and I'm not able to discuss numbers publicly. Thanks!
-Cam, Tweak'd Performance
Old 03-19-12, 10:22 AM
  #43
TweakTech
TweakTech's Avatar
For your viewing pleasure.
Old 03-19-12, 11:31 AM
  #44
suprandsc
suprandsc's Avatar
Entire build looks great! I can't wait till I get my harness back and get mine done!
gs350508
Build Threads
02-16-16 07:39 AM
belac
Build Threads
38
12-15-15 01:54 PM
SBM2jLEX
Performance
88
12-26-12 03:28 PM
SoarerAZ
07-31-08 06:07 PM
cliffud
Southwest
04-12-08 09:58 PM
Quick Reply: Tweak'd Performance 2JZ-GTE SC300 Engine swap
