Build Threads Details on Club Lexus SC owner vehicles
My 2jzgte swap
Old 11-18-11, 10:29 AM
  #91
Vwpride12
Vwpride12's Avatar
Originally Posted by TweakTech
Great progress! Love that exhaust! We ran into the overboosting problem on my customer's 2JZ SC300 we just finished. Kept hitting boost cut, exhaust didn't provide enough back pressure. We fabricated our own restrictor plates, which are removeable when our customer decides to upgrade turbos!
-Cam, Tweak'd Performance
Thanks! How much boost was it making. Did you have 3 inch all the way back? Where did you put the restrictor?
Originally Posted by princerani
Looking Pretty Sweet....
subscribed
Thanks!
Old 11-18-11, 10:51 AM
  #92
99SC42
gte & na-t
99SC42's Avatar
Aarron you can use your ge tps sensor if you still have it,same part!
Old 11-18-11, 11:08 AM
  #93
Vwpride12
Vwpride12's Avatar
I plugged in the ge tps to make sure my diag was correct. It spun the opposite way though. I think it would have sat upside down or connector pointing up on the throttle body.
Old 11-18-11, 02:52 PM
  #94
TweakTech
TweakTech's Avatar
Thanks!
We ran 3" all the way back to 3" duals with magnaflow mufflers. The two flanges that you see in the picture right infront of the resinators are were we put the restrictor. We basically took another flange and welded a piece inside it to "restrict" the flow. Worked perfectly. We now boost to 14psi with no boost controller. Before the restrictor plates were installed we were hitting 17~18psi then boost cut.
Old 11-18-11, 05:39 PM
  #95
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Is it better to go dual exhaust or single? Let the opinions come in...
Old 11-18-11, 06:17 PM
  #96
breed
breed's Avatar
Vwpride12: let me know if u need a restrictor ring, I recently had some extras made from my machine shop.
Old 11-19-11, 06:25 AM
  #97
TweakTech
TweakTech's Avatar
I don't think one style is better over another. It's more of personal preference! Both setups can look and sound amazing on an SC.
Old 11-19-11, 07:37 AM
  #98
Vwpride12
Vwpride12's Avatar
Cool, any pictures of the restrictor not installed?
I wanted to go single but I didn't like the exhaust cutout on the other side. Looked like something was missing.
Do you have a picture of it?
Old 11-21-11, 01:24 AM
  #99
breed
breed's Avatar
Vwpride12: Here ya go!
Old 11-21-11, 05:24 AM
  #100
DoomLight
DoomLight's Avatar
i kept mine dual. just liked the look better than single.
if you do plan on going single. at the very least. mold the opening that you arne't going to use closed.
on my car. i have 3 inch downpipe, then it splits at the Y pipe into two 2.5 inch pipes which lead to my mufflers.
which are the megan racing axle back mufflers.
Old 11-21-11, 06:13 AM
  #101
Vwpride12
Vwpride12's Avatar
Thanks Breed, So the opening on your "restrictor ring" is 2.5 inches?
Old 11-22-11, 12:10 AM
  #102
breed
breed's Avatar
Nahh, it's smaller then that. It's a 1.2 bar Restrictor Ring.
Old 11-25-11, 02:17 PM
  #103
Vwpride12
Vwpride12's Avatar
Got it running today on a base map. Still have to put my fuel pump in and do the tach mod. And either my PS pump is bad or the resevoir is messed up. But I should have all of that straightened out next week. Then Ill be taking it to get tuned!!!
Old 11-25-11, 03:35 PM
  #104
99SC42
gte & na-t
99SC42's Avatar
Aaron can you pm me the info on your tuner if you dont mind!
Thanks.
Old 11-25-11, 06:53 PM
  #105
megamax
megamax's Avatar
sweet. i might do that intake bung. thank for the insipration!!
Quick Reply: My 2jzgte swap
