Build Threads Details on Club Lexus SC owner vehicles
My 2jzgte swap
Old 08-24-11, 06:08 AM
  #31
Vwpride12
Vwpride12's Avatar
Traction control butterfly deleted, found some leaky cam seals
Power washed 200k miles of grime off, At least she will be clean when she dies...
I am doing seperate returns for each turbo, waiting on getting my oil return hard lines back with the AN fitting attatched. Why??? Because I can...
Flywheel resurfaced.
Crank
Waiting to go back together
And together.
My water pump, timing belt, cam seals, and tensioner should be here today, so hopefully ill have my covers back on tonight!!
Old 08-24-11, 07:01 AM
  #32
Vwpride12
Vwpride12's Avatar
waterpump and housing, coil to replace broken one, tensioner, cam seals, timing belt, and oil filter.
Old 08-26-11, 07:37 AM
  #33
Vwpride12
Vwpride12's Avatar
Finished my return lines last night, put the timing back together, and power washed the engine bay. I pulled both harnesses off last night and I am going to start with the wiring.
Old 08-26-11, 07:42 AM
  #34
Vwpride12
Vwpride12's Avatar
I have done some research on the sequential turbos and have read about rerouting some of the vacuum lines and putting a manual boost controller on the second turbo to regulate when it kicks in . I know it does not have a normal wastegate. I have read contradicting articles though. Has anyone on here messed with that.
Old 08-26-11, 07:58 AM
  #35
Vwpride12
Vwpride12's Avatar
http://www.max-boost.co.uk/max-boost..._the_beast.htm
Old 08-26-11, 09:25 AM
  #36
Triple C
Triple C's Avatar
Yes it is possible. i routed it that way when i had the twins and it helped spool them up but it also shortened there already short lived lives. To be honest you should start pieceing together your Single Turbo kit. Its what you want... really.
Old 08-26-11, 04:33 PM
  #37
AristoKing
AristoKing's Avatar
Very nice kept SC... Good luck with the build... Are you going stock for now?
Old 08-26-11, 05:37 PM
  #38
iridebmx
iridebmx's Avatar
why doesnt anyone do drift motions twin turbo rebuild/upgrade instead of single? i hear lag is a small issue once your above 300hp on the 1jz
http://store.driftmotion.com/static/...aderebuild.php
Old 08-26-11, 08:15 PM
  #39
DoomLight
DoomLight's Avatar
The twin oil drain seems a bit overkill to me. I look forward to you completing this project.
Old 08-30-11, 06:27 AM
  #40
Vwpride12
Vwpride12's Avatar
Yes, I am going to run the stock twins
Old 08-30-11, 06:28 AM
  #41
Vwpride12
Vwpride12's Avatar
I am pretty sure this was cheaper than getting the parts from the dealer and I didn't have to wait a week for the parts.
Old 08-30-11, 06:29 AM
  #42
Vwpride12
Vwpride12's Avatar
Organized Chaos...
Old 08-30-11, 06:40 AM
  #43
99SC42
gte & na-t
99SC42's Avatar
it's really not it's $28 and it's a 2 days order, it's all about what you like and how much skills you have to make your own stuff
Old 08-30-11, 08:38 AM
  #44
1WILLY1
1WILLY1's Avatar
man that wiring is a mess , I wouldnt know where to start even.
Old 08-30-11, 09:09 AM
  #45
DoomLight
DoomLight's Avatar
I agree if you were just going to do a wire extension, you wouldnt wanna have to unravel so much of the harness.
Quick Reply: My 2jzgte swap
