HELP, messed up electrical experiment
Hey guys, I just did an auto to R154 swap on a 96 OBDII SC300 and had one CEL I couldnt fix. I had a friend give me a suggestion to fix it. The problem was with vehicle speed sensor 2, there was no signal since the auto was out. So what I did was use a ripple binary counter to divide the frequency of VSS1 to send to VSS2.
I spliced into SP1 of the ECU, which is the output signal from VSS1 and I ran that to the counter and the output from the counter to SP2+ of the ECU(VSS2 signal)
Everything seemed operational at first until I tried to start the car. I hear the starter work for a split second. Then all power is cut, all the lights in the car stopped working. If I take the keys out, there is slight power since I see the door ajar bulb dimly light as well as the door light. When I try starting it again, nothing.
I checked all the fuses and they are all still intact. I've already removed the circuit I installed. Anyone have any ideas?
I
I
Greyhorne
10-09-10 08:26 PM
dante1616
03-11-08 08:28 PM
